Old 08-21-2005, 10:21 PM   #1
snp_ethan
snp_ethan is an unknown quantity at this point
Send a message via AIM to snp_ethan
s14 ka24de dont start, elec problm help
its a zenki, as i put the key in the ignition i get interior light, but as soon as I start turning the key it all goes dead.(on the first contact)
after about 1o seconds the int light goes off once again, I try it and same thing again...
do I have any shorts on the ground wiring? if yes which one could I try cuz I checked all the wires that leave the battery into the motor itself and I tried to look for the bunch but I could not see, cuz its parked on the streets.
i've searched but there is nothing
i looked in the bay area but everything seems ok
what is wrong?
BTW it doesnt crank, I tried to jump start it but I get the same results, which means its not the battery, the alternator nor the ignition.
if there are any other suggestions, throw them at me..
snp_ethan is offline   Reply With Quote
Old 08-22-2005, 04:29 PM   #2
snp_ethan
anybody?
Old 08-24-2005, 01:05 AM   #3
snp_ethan
hello? anyone can gimme a hand?
Old 08-24-2005, 01:07 AM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
jack it up and check your starter ground
also check your battery terminals and make sure they're secure.. then go to the fuse box..
Old 08-25-2005, 03:54 AM   #5
snp_ethan
i did nothing happening. any other ideas?
Old 08-25-2005, 10:17 AM   #6
NemeGuero
No more nissan.
NemeGuero's Avatar
start checking all fuses and relays. Get out a multimeter and the FSM... If it's not a broken connection somewhere, you might want to check your ignition mechanism itself.
If I'm understanding this right, when you turn the key power cuts off. You have interior lights but nothing else? Power isn't getting to your starter, or you'd be able to crank the motor at least. So something electrical isn't right. This isn't my strong point, I'd take it in because it takes a long time to trace the sources of electrical error.
Old 08-25-2005, 11:59 AM   #7
Johnson
Johnson is an unknown quantity at this point
i kinda had the same problem. had it towed to the shop. he told me something about having to repair the wiring harness and the starter was bad
Johnson is offline   Reply With Quote
Old 08-25-2005, 01:43 PM   #8
SDS14Driver
SDS14Driver is an unknown quantity at this point
have you tried bypassing the starter relay. Try to isolate the electrical problem to a single component if possible when doing your tests. bypass the relay and start the car and see how things run. Your engine management system's running on the same power source as your car's lighter so if your engine runs the way its suppose to i'd look closer at the electrical components responsible for starting ignition.
SDS14Driver is offline   Reply With Quote
Old 08-25-2005, 03:00 PM   #9
NemeGuero
No more nissan.
NemeGuero's Avatar
is there an echo in here?
Old 08-25-2005, 07:10 PM   #10
snp_ethan
ok.. may be I wasnt clear enough.. lets see, I open the door, the ceiling light turns on, so I guet that, and from now on that will be int light or IL.
I put in the key and and turn it to the first stop. radio goes off, so I do get sound for a split second and then everything goes dead.. the IL goes dead, and then after a min or 2 i start to get a dim IL and then it goes into full power again..
was that clear?
Old 08-25-2005, 10:47 PM   #11
vltnolia
vltnolia is an unknown quantity at this point
Get A New Battery
vltnolia is offline   Reply With Quote
Old 08-25-2005, 10:48 PM   #12
vltnolia
Start Checking Voltage!!!!!
Old 08-26-2005, 01:06 AM   #13
snp_ethan
ok... like I said.. i tried to jump start the car, and it didnt work, its not the battery....
i checked the voltage on a couple of terminals.. but do oyou have any specific one?
Old 08-26-2005, 11:56 AM   #14
NemeGuero
No more nissan.
NemeGuero's Avatar
yah, the big 2 on the battery
Old 08-26-2005, 12:21 PM   #15
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Might want to have your battery tested.
You could have a faulty ignition switch and/or blown fuses. Look at the fuse/relay box behind the battery. Do you hear any relay click when you put key in/turn key? It sounds like a bad battery IMO....
GL
MELLO*SOS is offline   Reply With Quote
Old 08-26-2005, 10:56 PM   #16
snp_ethan
ok.,,, damn, I've checked almos every ground wire but nothing loose, so Im thinking about the ignition switch... l\will let you know tomorrow..
Old 08-27-2005, 02:29 AM   #17
snp_ethan
humm ok hold on.... I just thought of this:
if the whole electrical system goes dead and then it takes it a while to get back on track, there is something that just doesnt fit here..
I mean if the ignition switch was gone bad, then that should not affect the rest of the electrical system, should it? because I do have some downtime (or lag, whatever you wanna call it) in between trying to start and letting it get back to basic IL ...
so, Im totally lost.. any ideas?
I still will try the ignition switch... but just some food for thought...
Old 08-27-2005, 07:27 PM   #18
snp_ethan
ok, I got a new switch, changed them but now I get this cranking from the left side of the panel,right next to the wheel that would be my left side if sitting at the wheel..
so what am I supposed to do now?
Old 08-27-2005, 08:42 PM   #19
snp_ethan
GL
so, i did change the switch, and now I hear a click (like I said in the previous post, but still nothing I checked all fuses, they are all in order. but then the relays on the driver sides, I havent checked those.. for I dont know what they are, and I dont have an FSM on me right now...
and once again im pretty sure it is not the battery, I get 12.5
Old 10-04-2005, 10:11 AM   #20
obsolete
obsolete is an unknown quantity at this point
old post, but i'm having the same trouble right now w/ my s13. I have to keep going out and play w/ the negative terminal on my batt. once i get power, i try starting the car and it shorts out. i repeat until i could get the car started. before this started happening, when i tried to turn the ignition, there would be a click and i would have to do it several times before it would actually start. snp ethan did you end up finding what was wrong?
obsolete is offline   Reply With Quote
