Old 08-27-2005, 01:15 AM   #1
xagna
xagna has a little shameless behavior in the past
a wierd handling problem, need an advice.
I was doing some slalom like maneuvers and just found this out.
When I turn the steering wheel any direction all of sudden with very strong force, only handle goes around while the car's response to the sudden steering input comes less than a second late. It is a rubberish feeling I get through the steering.
What could be wrong and should I replace? I feel like it is one of the bushings but not sure.
xagna is offline   Reply With Quote
Old 08-27-2005, 01:37 AM   #2
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
Crank the wheel very quickly and you'll upset your suspension and compromise grip, leading to what I believe is driver-induced terminal understeer. Smoothness is your friend.
What kind of suspension mods are you running? What kind of tires?
Next time, please write a more coherent post. That was hell trying to understand at midnight and a half.
KA24DESOneThree is offline   Reply With Quote
Old 08-27-2005, 09:31 AM   #3
stu8319
stu8319 is an unknown quantity at this point
Send a message via ICQ to stu8319 Send a message via AIM to stu8319
Check your ball joints.
stu8319 is offline   Reply With Quote
Old 08-27-2005, 09:57 AM   #4
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
Sounds like tall tires to me. Garbage tires with lots of side wall are not good for much but burnouts. Try adding air pressure if you are not getting good response. Too much air though will kill your grip.
If you want to spend money to cure the problem get wider/taller wheels and better tires with shorter sidewalls. Then good suspension parts.
SpeedMonkeyInc is offline   Reply With Quote
Old 08-28-2005, 04:17 PM   #5
xagna
Sorry, forgot to tell you what I had in my wheel well.
s13
megan coilover. 2.5 camber in the front.
hankook h405 215/45/17
You sure this is an understeer problem? I don't hear any squeaking noise from the tire when I turn at 60mph. Feel that I can from steering wheel is also different comparing to other s13s when I do same maneuver.
stu8319, when I check the ball joints what kind of things do I have to look for? Cracks?
Old 08-28-2005, 04:26 PM   #6
slivia-junkie
Location: if you could tell me i would be most greatfull
slivia-junkie is an unknown quantity at this point
when cheching ball joints jack up wheel under load(put jack under controle arm). and see if the wheel has movement side to side and top to bottom. by inspection standerds 1/16 inch failing but you want none. also check your steering shaft for play/ binding
slivia-junkie is offline   Reply With Quote
Old 08-28-2005, 04:54 PM   #7
kandyflip445
kandyflip445's Avatar
Buy a Nismo power brace and t/c rods if you don't already have them.
My 240 vBgarage
Old 08-29-2005, 03:24 PM   #8
xagna
Thanks for the advices.
I do have a free wheel play. IT is about half inch to both directions.
kandyflip445,
Could you tell me how a tension rod and power brace will help me with this? I don't understand. I was thinking that tie rod end might help instead.
Old 08-29-2005, 10:43 PM   #9
kandyflip445
With my car there was slop in the steering when doing stuff like that. When I installed those it helped A LOT. PS rack bushings helped A LOT also.
My 240 vBgarage
