Old 09-16-2005, 12:51 AM   #1
importsaint
importsaint is an unknown quantity at this point
Send a message via AIM to importsaint
KA Car Won't start!!!
1993 240sx SE 5-speed HB
Ok so about three months ago I was in a rear in collision, my front end ended up under a minivan in front of me. The car started and I drove home from the accident. When I went to start it a few days later it would not start. I replaced all the parts related to the accident (radiator, did an S13 front headlight swap, A/C condenser). I timed the car completely and it started, but when I went to give it gas it just dropped RPMs and died. The parts I have replace are my fuel pump, ignition switch, ECU(M), Camshaft Position Sensor and distributor, knock sensor, ignition control module, ignition coil, intake pipe (was cracked in accident), and starter. I am about to replace the Crankshaft position sensor, can someone give me some advice, I am getting fuel and spark too! Please someone help me!!!!
Import Saint
importsaint is offline   Reply With Quote
Old 09-16-2005, 07:10 AM   #2
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
Check your TPS...
TPS and MAF tell the ECU what it need to know for driveability and timing advance...bad TPS could cause your problems for sure.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 09-16-2005, 06:23 PM   #3
jaja
jaja is making a name for him/her selfjaja is making a name for him/her self
Send a message via AIM to jaja
go to the junkyard and get a new KA
93 S13 Vert: KA, 5 Spd, intake, exhaust, coilovers, etc
94 bronco: 6"+35"
jaja is offline   Reply With Quote
Old 09-25-2005, 09:54 AM   #4
importsaint
I replaced the TPS today still nothing , and I swear the timing is correct. I am feeling like saying F-it and swapping for an SR , but I don't want it to end up being a problem that carries over.
Import Saint
