Old 09-21-2005, 08:44 AM   #1
importsaint
importsaint is an unknown quantity at this point
Send a message via AIM to importsaint
Question Headlights are screwed
I've had this problem for a while now, where when I turn on my headlightsonly one works at a time. When I had my factory USDM pop-uplights I tried changing the bulb assembly on the side that would not light up during low-beam operation. Didn't work, I know have swapped on the S13 front end, due to a front end collision. Now when I turn on my lights the low beam on the driver's side is on, and the passenger side is off. When I turn on the high beams the driver's side doens't work, and the passenger side projector works. What the F is the problem can someone help... PLEASE!!!
Import Saint
importsaint is offline   Reply With Quote
Old 09-21-2005, 10:03 AM   #2
kandyflip445
kandyflip445's Avatar
Wiring! Take it to a mechanic.
My 240 vBgarage
Old 09-21-2005, 10:33 AM   #3
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
Could be the switch...try a known-good stalk.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 09-21-2005, 11:09 AM   #4
cotbu
cotbu's Avatar
start by making sure your they work, make sure your have power at the lights (use test light) for H\L check fuses, maybe rewired and power for that light could come from somewhere else.
Old 09-21-2005, 11:16 AM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
yah, shitty wiring, didn't you have to splice for the headlights anyway? you coulda checked voltages there...
Old 09-25-2005, 09:51 AM   #6
importsaint
I did not have to splice wires, they came with a plug that fit straight up to my originals plug. The only splicing i did was hooking the middle amber projectors up to my old headlight pop-up button on my dash.
Import Saint
Old 09-25-2005, 10:40 AM   #7
smily_vigor
smily_vigor's Avatar
smily_vigor is an unknown quantity at this point
Send a message via MSN to smily_vigor
Did you remove the two headlight motor relays located in the fuse box in the front portion of the engine bay on the drivers side and loop the wires together? I think the colors are light pink and purple, my car is at the shop right now so I cannot go check on mine. You need to do this if you wired lights into your exsisting pop up light switch. There's a write up on this site with a guy that shows it with a diagram. Do a search for "jdm lights" or "projectors" and it should come up.
smily_vigor is offline   Reply With Quote
