Old 09-25-2005, 06:01 PM   #1
chnco
chnco is an unknown quantity at this point
S13 Diff Cover on S14?
Haven't had the chance to have them side by side, but could it be possible to just use 2 of the 4 bolts on the S13 cover rather than swapping covers? I'm just curious.
Also, any other differences physically with S13/14 pumpkins? Straight up swap but the cover? I'm putting a S13 pumpkin into a S14. Just want to make sure I don't run into any problems.
chnco is offline   Reply With Quote
Old 09-25-2005, 06:59 PM   #2
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
not sure about the s13 cover working on s14, but it seems like the bolts/studs on the s14 cover are quite a bit longer than the s13 ones, so i assume you'll need to swap covers anyway, but they pumpkins are the same, just covers, i believe the abs ones are different? about or almost an inch longer than a non abs one
Indolent is offline   Reply With Quote
Old 09-25-2005, 08:30 PM   #3
Dousan_PG
Dousan_PG's Avatar
no you cant.
just swap rear covers. takes 5 mins max.
Aaron
Pink GodziRa
Old 09-25-2005, 08:55 PM   #4
projectRDM
projectRDM's Avatar
Other than the front mounts, the diffs are identical. Swap covers. Quit being lazy.
FORMERLY R240NA
Old 09-25-2005, 09:19 PM   #5
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
^^^ what EVERYONE said. Its quick.
SochBAT is offline   Reply With Quote
Old 09-25-2005, 10:05 PM   #6
chnco
I know, I'm being lazy. I'll swap up the covers.
Do the front mounts need to be modified? From what I hear, the holes are a bit larger on S14's, so do I need to drill it out a little? Or am I backwards?
Old 09-25-2005, 10:09 PM   #7
blu808
blu808's Avatar
The holes on the s14 diffs are larger because s14 diffs have bushings in them. It is actually nice to eliminate those by using the s13 diff that doesnt use the bushings.
Old 09-25-2005, 10:20 PM   #8
Dousan_PG
Dousan_PG's Avatar
no drilling required
everything is bolt in once you swap the covers.
yeah s13 diff is coooool.
Aaron
Pink GodziRa
