Old 09-26-2005, 05:40 PM   #1
d r i f t swift
d r i f t swift's Avatar
d r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the rough
why does my clutch's hydraulic system build up "extra" pressure?
heres the deal. just finished the 5spd swap, took out the clutch dampener box, rebuilt the slave cylinder, using a used master cylinder from the jy.
now the problem.. bled the clutch thought it was fine until i drove it and realized it was slipping. so i jacked the car up to check if the clutch was disengaging all the way..so i backed off the bleed screw on the slave cylinder and the clutch pushed the slave cylinder rod back in. so i was driving the car with the clutch half way disengaged. the next morning the same thing happened. so my question is why the hell does it do that? it builds up "extra" pressure almost instantly if anyone can help me out id appreciate it thanks.
rip bobby.. you will be missed..
d r i f t swift is offline   Reply With Quote
Old 09-26-2005, 05:46 PM   #2
kandyflip445
kandyflip445's Avatar
Restricted line, pedal free play or the MC cup seals aren't working right. You could try a new MC and see if it works right.
My 240 vBgarage
Old 09-26-2005, 07:40 PM   #3
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
kandy, what do you mean by MC cup seals? The rounded rubber seal inside the MC cap??
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 09-26-2005, 07:46 PM   #4
kandyflip445
They're the rubber cup seals that are in the cylinder of the MC. Part of the moving assembly.
My 240 vBgarage
Old 09-26-2005, 09:10 PM   #5
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
If you didn't make a typo then that is probably the problem. First of all, seals should be new if you're planing on rebuilding something. Second, using master cylinder parts to rebuild a slave cylinder? I aint hearda dat....
-Juan
240Stilo is offline   Reply With Quote
Old 09-26-2005, 11:23 PM   #6
kandyflip445
I'm pretty sure he meant that he rebuilt the slave and is using a MC from the junkyard.
My 240 vBgarage
Old 09-27-2005, 01:54 AM   #7
d r i f t swift
well i put in a new master cylinder and that wasnt the problem.. the "extra" pressure wasnt really extra, the slave cylinder somehow was getting stuck halfway out so i replaced the slave cylinder and that seemed to do it. well for now. we'll see what happens tomorrow
Old 09-27-2005, 07:00 AM   #8
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
Typically, if it works fine, then builds up presure as you drive...you have too little clutch pedal freeplay, and need to adjust the rod on the clutch pedal.
Do it 1/2 a turn at a time...keep adjusting, then drive it...if it builds pressure again, add more freeplay, then drive it again, etc...
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
