Old 09-30-2005, 01:08 AM   #1
Skaterjunky8
Skaterjunky8 is on the path to ruinSkaterjunky8 is on the path to ruin
Starting problem
I got an All stock Kade and it doesnt start:
The starter seems to be going, and the clutch fan spins, but it just doesnt turn over, and it doesnt sound like a car normaly does when it starts it just whines.
THe car is 5-speed and we can kick start it just fine the car runs like a champ.
We changed the starter with a brand new one today and still nothing. We tested the coil and spark plug wires and we are getting spark. Any ideas?
Skaterjunky8 is offline   Reply With Quote
Old 09-30-2005, 02:15 AM   #2
mixedwell
mixedwell is an unknown quantity at this point
Send a message via AIM to mixedwell
check your ignition wires. make sure all grounds are good. do a search. good luck.
silvia... my love ::
mixedwell is offline   Reply With Quote
Old 09-30-2005, 06:03 AM   #3
xka24detx
xka24detx is an unknown quantity at this point
this happened with my friends old truck.. ended up being dirty/corroded battery terminals.. try cleaning them..
xka24detx is offline   Reply With Quote
Old 09-30-2005, 02:54 PM   #4
Skaterjunky8
the thing is the car used to start just fine but it seems to have developed this problem out of no where. I'll check the timing and some other stuff today and see whats up
Old 09-30-2005, 02:58 PM   #5
Skaterjunky8
Should I be looking at electrical problems to fix it? Cause it runs fine when its kick started, other then a low idle
Old 09-30-2005, 03:06 PM   #6
kognition
kognition's Avatar
kognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfection
If it runs fine when you "kick start it", then it is very likely to be a connection issue. Start at the battery terminals and clean them well with some mild sandpaper or steel wool. Use gloves because of the lead terminal (lead dust is toxic). And as others have suggested, check all your grounds.
EDIT: Just noticed your are in the Islands,,,, all the more reasong to have a corrosion problem where current carrying wires are connected. And pick up a good dielectric grease and apply that on your connections. This prevents micro
arcing and oxidation buildup at the battery terminal
kognition is offline   Reply With Quote
Old 10-08-2005, 12:34 AM   #7
kognition
kognition's Avatar
But your battery terminals are usually the culprit.
Old 10-08-2005, 11:46 PM   #8
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
If you "kick start" your car you have bigger problems...First of all it's push start, and you most liekly have problems with your battery, battery cables to the starter (Ground or Power) or you have a starter problem.
If you can push start the car and it runs fine why would you be checking the spark plugs and such, just pointless...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
