Old 10-03-2005, 07:17 PM   #1
[email protected]
choiboi86@hotmail.com is an unknown quantity at this point
Send a message via AIM to choiboi86@hotmail.com
cleaning throttle body, and stalling problems
ok i searched and it seems to be a common problem. my engine dies when i put it in neutral, like my rpm drops too fast. its a sr20 btw. i noticed it usually drops in hot weather, so maybe is related to hot air. when i drive like early in the morning the rpm doesnt drop as quickly so it wont stall. so i cleaned out maf and today just cleaned out throttle body but my car was having problems. tell me if i was cleaning out the TB the right way or not.
i sprayed some TB cleaner into it while moving the butterfly valve manually for a few seconds. then when i would start the car it would have problems, like it wouldnt start unless i crank it for awhile and gave it some gas. and once it would turn on the idle would be rough for awhile and this think smoke started coming out from my exhuast. i would leave my car on for awhile to get rid of the smoke. then i started again with spraying the cleaner into my TB and turning it on again. is it normal that this happens in the beginning?
and can someone tell me where the coolant temp sensor is located? a picture would help cuz i cant tell where it is.
any help would be appreciated. thanks
choiboi86@hotmail.com is offline   Reply With Quote
Old 10-03-2005, 07:22 PM   #2
A Spec Products
A Spec Products's Avatar
coolant temp sensor is by where the upper radiator hose connects to the engine
it should have a red colored harness plug
A SPEC PRODUCTS CORP
Old 10-03-2005, 07:30 PM   #3
SHIFT_control
SHIFT_control's Avatar
SHIFT_control is a well-known jackass
You are definatley cleaning the TB the right way. Another trick is using an old toothbrush to get more of the carbon out. My old Pathfinder had the same problem, and amazingly enough the TB cleaning cured it.
'93 Pathfinder SE daily driver
'93 HB blue (under construction)
'89 Celica GTS RIP
SHIFT_control is offline   Reply With Quote
Old 10-03-2005, 09:09 PM   #4
[email protected]
hmm cant find any red plug. i see a brown one. can anyone take a picture of where on the engine its located. and how exaclty would u clean the cts? would i spray cleaner on it or like use a clean cloth and just wipe the plug?
thanks for all the help guys
Old 12-19-2008, 07:19 AM   #5
obsolete
obsolete is an unknown quantity at this point
Really old thread, sorry. But I have the same exact symptoms. Did you figure out why it wasn't starting right and blowing smoke? How is coolant temp related to this?
obsolete is offline   Reply With Quote
