Old 10-11-2005, 12:00 AM   #1
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
check engine light blinks but ECU wont flash codes
OK so i have a S14, with a SR20det, the ecu is the correct ecu, no problems there. wiring was done by a good shop and everything works fine, motor runs great. except once every 20 or 30 seconds at idle u can hear a hiccup, and every so often the check engine light comes on when i start he car up and wont go away until the car is turned off. the light instead of staying on, blinks like a mofo, sometimes i stays on for 2 seconds, blinks 10 times, stays on for 5 sec blinks 2 more times, etc etc. so as you can see there doesnt seem to be any ryme or reason to the blinking. ALso i check the ECU and try to throw a code and the code light doesnt come on, doesnt blink at all.
i recently did not have my knock sensor connected and someone suggested it was most likely the sensor, so i connected it up, and still, its pulling the same BS. hiccups, engine lite, throws no codes. this doesnt happene very time i turnt he car on, only maybe 1/10 and it stays on from startup till when i stop it. someimtes itll happen 2 or 3 times in a row for like 2 days strait. anyways, has anyone seen this problem before? any suggestions as to what it could be because im totally clueless.
thanks
redsuns3838 is offline   Reply With Quote
Old 10-11-2005, 11:42 AM   #2
redsuns3838
nobody has any idea what could be causing this or what i could do to find out? =/
Old 10-11-2005, 11:49 AM   #3
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
blinking CEL generally means a intermitent misfire.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 10-11-2005, 08:45 PM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
and maybe the light bulb on your ecu is burnt out.. so you really wouldn't see a code
Old 10-12-2005, 02:10 AM   #5
redsuns3838
how can i make sure its a misfire? aside from bad timing what else could cause it
Old 10-14-2005, 02:06 AM   #6
redsuns3838
nobody has an idea? am i not giving enough info or a poor discription?
Old 10-14-2005, 02:14 AM   #7
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
Maybe unplug your battery for awhile and see if the Cel still blinks after a few days of driving.
breakindrifts is offline   Reply With Quote
Old 10-14-2005, 03:56 AM   #8
redsuns3838
hehe thanks for the idea but i dont think that is the problem. battery has been unplugged for several days at a time while i work on my car from time to time, and this isnt fixing it. its not a recent problem.
Old 10-14-2005, 04:02 AM   #9
cotbu
cotbu's Avatar
OK. When you set the ecu to diagnostic mode does the check engine light blink then?
If not break out the test-light, multimeter or take it back to your mechanic.
You could also get an ECU from a friend, try it document everything give it back. You'll then know where you stand.
Also disconnecting the battery for a while (in between actions) will give you a good starting point, if you cant fix it.
Old 10-21-2005, 04:11 PM   #10
redsuns3838
cotbu the check engine lite does not blink when i set it to diagnostics mode.
does anyone think there could be a prob with the compatability of my engine
Chassis is a 96 (OBDII) S14 SR engine is a 95, and the engine wiring harness is an auto Kouki harness (not sure which yr 97 or 98)
