Old 10-12-2005, 01:11 AM   #1
monkey_man
monkey_man is an unknown quantity at this point
Need some help installing new turbo
hey i need some help installing a new t28 bb turbo on my sr20det redtop. Do u know what is needed to install it so far i have these item
-S14/S15 Turbo Oil Return Hose
-S14/S15 SR20 Turbo Oil Return Tube
-S14/S15 Turbo Outlet Pipe
-S14/S15 Turbo Inlet Pipe
would the stock t25 manifold work with it?
and is that all i need to install?
Do i have to custom a hotpipe?
(¸.·´ (¸.·´ .·´¨¨°º3 stArRº°¨¨°º
monkey_man is offline   Reply With Quote
Old 10-12-2005, 10:19 PM   #2
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
mock it all up and see what you need.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 10-13-2005, 12:45 AM   #3
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
IIRC, T25, T28, and T3 flanges are the same.
Do what GayDan told you to do, and mock fit them.
Common sense should kick in by then.
SochBAT is offline   Reply With Quote
Old 10-13-2005, 06:44 PM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
you most likely will have to have your downpipe modified to fit, the turbo exhaust port is probably different
you can get the intake piping to line up probably with just a little rotating of the compressor housing
