Old 10-15-2005, 07:20 AM   #1
KOUKI KA-T
KOUKI KA-T's Avatar
KOUKI KA-T is on a distinguished road
Rear subframe Q's
My sub frame bushings were pretty garbage and I installed the aluminum spacers (not the collars) over a year ago. The subframe is now starting to clunk again, and upon inspection it seems the stock bushings are just plain toast now.
Would replacing the single spacer with a set of poly collars be enough to tighten the subframe back up even though the stock bushings have been compressed and mangled to crap, or should I just replace all the OEM subrame bushings?
And if I do the latter, the ES poly bushings for the z32 rear subframe are a direct fit in the 240 subframe, correct?
Thanks for the help.
My car has been sold
KOUKI KA-T is offline   Reply With Quote
Old 10-15-2005, 07:28 AM   #2
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
damn, this is why i wanna drop my subframe and install new bushings while the motor is out, i had a feeling these spacers wouldnt last forever, my bushings look pretty damn nasty too. Id say replace all the bushings with some poly or solid ones
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 10-15-2005, 12:28 PM   #3
l33tmonkeyman
l33tmonkeyman is an unknown quantity at this point
Send a message via AIM to l33tmonkeyman
id say not to waste ur money and effort on poly ones. go for solid. they do project a little more sound into the cab though, but nothing too bad. just pretty much get the subframe off, stick a sawz all in the center and cut to the side of it. Then pound it out with an air hammer.
l33tmonkeyman is offline   Reply With Quote
Old 10-15-2005, 12:54 PM   #4
KOUKI KA-T
KOUKI KA-T's Avatar
I'm all set with solid ones, it's a daily driver, no need to have solid bushings.
Old 10-15-2005, 01:53 PM   #5
l33tmonkeyman
heh, i got solid aluminum ones and mine is a daily driver. Just adds to the fun.
Old 10-15-2005, 04:35 PM   #6
projectRDM
projectRDM's Avatar
ES Z32s fit fine. Same bushing.
FORMERLY R240NA
Old 10-15-2005, 04:36 PM   #7
KOUKI KA-T
KOUKI KA-T's Avatar
I was waiting for you to chime in, thanks Russ.
Old 10-15-2005, 04:37 PM   #8
projectRDM
projectRDM's Avatar
Send beer.
FORMERLY R240NA
Old 10-15-2005, 04:44 PM   #9
KOUKI KA-T
KOUKI KA-T's Avatar
Send beer.
wanna add a pizza to that??
How about the diff carrier bushing?
Old 10-15-2005, 05:03 PM   #10
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
you have the SPL complete solid spacers, or the drop-in ones?? If the drop-in 4-piece or 8-piece? I have the 8-piece ones. They squeezed the rubber junk out, so next i'm going to go ahead and burn out what remains then toss them back in for metal-metal contact.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 10-15-2005, 09:51 PM   #11
projectRDM
projectRDM's Avatar
Too late, I'm already drunk. Diff bushings are the same too. Note that the ES kit is slightly different than the OE or Nismo bushings and rely on the tension of the diff to secure them. I think that sounds right anyway.
Another good trick is to find Delrin diff bushings, I lucked out and found a front pair on YahooJP a while back for cheap, they're solid as hell but leave the rear bushings soft, giving you some play without it being solid mounted. Even with that setup my old car was loud as hell, but you could definitely feel the difference when the driveshaft torqued up.
FORMERLY R240NA
