Old 10-24-2005, 06:43 PM   #1
blu808
blu808's Avatar
$100 Hydro Ebrake how to
Ok guys i allways wanted a hydro ebrake for my s14.5 but i never got around to it. Heres some somewhat detailed instructions on the setup. It is really easy, and only takes about an hour.
First call up CNCbrakes.com and order the "staging brake" for disc brakes. $95
Then find a mounting point.
Then make a mounting bracket.
Mount it up.
Now find the hard line that goes to your rear brakes.
Dissconect the line from the rear, and bend it up to the front of the staging brake. Now go to auto zone and buy a 5ft hard brake line. Hook this up to the rear brake valve, and bend the other end up to the exit of the staging brake.
Bleed the system and you are done. Total cost $100. Gangster value: Priceless.
blu808 is offline
