Old 11-07-2005, 10:27 PM   #1
Tits952
Tits952 is an unknown quantity at this point
argggh no spark (i've searched)
well no spark as the topics stated. there is no power to the ignitor. no power out of the pins to the ignitor. the ecu does get power. everything else "seems" to work (fuel pump, injectors)
running a sr redtop with a q45 ignitor and a #62 ecu? aight who wants the cookie???hhhaah help please and thanks in advance
does this sound like a bad ecu
Tits952 is offline   Reply With Quote
Old 11-09-2005, 02:09 AM   #2
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
Tried testing spark at the coilpacks too? Hear the fuel pump turn on? Fuel squirting out from the fuel lines? Battery full? If not these then check your wiring again or could be bad ecu.
silverarrow27 is offline   Reply With Quote
Old 11-09-2005, 02:48 AM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
he said theres no spark, not no fuel.
sounds like a fuse to me(or bad ECU) because between the ECU and the ignitor it looses power somehow. dunno much about SRs though
Old 11-09-2005, 04:06 PM   #4
sdtouge
sdtouge can only hope to improve
sounds like bad wiring
check the wiring beind the battery
especailly the blue and red and red and blue wires (there is a differnce) and that could do it.
sdtouge is offline   Reply With Quote
Old 11-09-2005, 06:29 PM   #5
Tits952
hmm. ill look into that.
