Old 11-08-2005, 05:17 AM   #1
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
s13 help with ka24e won't start. gots air fuel and spark.
rebuilt the whole damn thing. as in, changed head gasket, and some other gaskets :P so not really rebuild, ok fine, i changed the headgasket.
so now, i have fuel, spark, and air, but the damn thing won't start.
i have the exhaust manifold off, so when i crank it, i see the damn fuel comin out white, like, no combustion.
and i checked for spark, i changed new wires and new spark plugs, and the spark is there, i see it. bosch platinums.
i crank i crank, i crank some more, like, 20 seconds, well, friend cranks, and i push the timing back and forth. not even close to firing up.
checked compression, brand new head gasket, but everything else is origional, head and pistons rings are old. 120 150 150 150
what is the ups! start damnit, help me. i heard i should check coolant and air temp sensors, but damn, it doesnt even get close to startin.
i checked grounds, didnt really know which ones, i only see one near the egr/exhaust manifold tiny little ground, and the other ground is the one near the battery tray, injectors are all grounded to the head.
help me im so sad.
95zilvia is offline   Reply With Quote
