Old 11-08-2005, 07:56 PM   #1
jt1583
jt1583 is making a name for him/her selfjt1583 is making a name for him/her self
capping off throttle body coolant lines?
my throttle body for ca18det has two small coolant lines running to it, i already capped off the sources with coolant caps and covered nipples on tbody with vacuum caps, car will be running fri or sat, im just curious why they were there and what will be the side effects. having coolant run through and heat the tbody seems like a reverse intercooler and like its there for emissions/fuel mileage anyway, maybe cold starts too.
jt1583 is offline   Reply With Quote
Old 11-08-2005, 08:24 PM   #2
DP_Michelle G
DP_Michelle G's Avatar
DP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really nice
It's only there for emissions. There's no side effects from removing them
DP_Michelle G is offline   Reply With Quote
Old 11-09-2005, 08:53 AM   #3
projectRDM
projectRDM's Avatar
Cold starting, and to keep the TB from icing in colder climates.
FORMERLY R240NA
