Old 11-18-2005, 04:47 PM   #1
Kuno3x16
Kuno3x16 is an unknown quantity at this point
blinkers don't work...
I have a 1995 240sx...
my signals don't work... i tested the combination flasher and it works fine... there seems to be no power going into my combination flasher for some reason... fuses are fine... anyone know what else i can check???
thanks =)
Kuno3x16 is offline   Reply With Quote
Old 11-19-2005, 10:18 AM   #2
projectRDM
projectRDM's Avatar
Hazard switch.
FORMERLY R240NA
Old 11-20-2005, 02:18 AM   #3
Kuno3x16
thanks but the hazards work...
Old 11-20-2005, 02:23 AM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
turn the key, put the blinker on and get out a voltmeter. See if you get any voltage pulsing from behind the blinker.
Old 11-20-2005, 09:22 AM   #5
projectRDM
projectRDM's Avatar
Agreed, if the hazard switch is good then the turn signal switch itself is bad, there is no other part in the system like a control unit or timer.
FORMERLY R240NA
