Old 05-10-2002, 08:15 AM   #1
NooKa311
NooKa311 is an unknown quantity at this point
I bought a 91 240SX Tuesday and I wanted to see if it had a LSD so I burnt out and it left rubber from both wheels.  But I thought all the S13s didn't have anytype of LSD.  I'm not sure what model my car is, but I think it's probably the lowest of the hatchbacks.  No sunroof, power windows or locks, ABS, or spoiler.
I'm kind of new with this type of car, I had the real deal 300Zs (88T & 90TT), but I wanted to give the SR20 a try.
91 240SX (Stock) w/215k miles - ET 15.9, Honda Civic SI w/VTEC - ET 16s
NooKa311 is offline   Reply With Quote
Old 05-10-2002, 01:36 PM   #2
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
It is possible to break enough traction to get an open diff to spin both wheels..  If you don't have HICAS then you don't have LSD..  UNLESS someone installed it afterwards.
sykikchimp is offline   Reply With Quote
Old 05-10-2002, 01:43 PM   #3
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
same thing happened in my friend's '92.... I'm thinking that his open-diff at least thinks it's a VLSD, so I'm going to try swapping it into my car (he just bought a HICAS diff to replace it to make sure he has VLSD) and see how it goes <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
AceInHole is offline   Reply With Quote
Old 05-10-2002, 01:59 PM   #4
sykikchimp
WOW addicted
sykikchimp's Avatar
I've done it in my 92 as well. escpecially if the ground is a little wet. I can get both wheels to go crazy. But, alas, it's not always that way. About 2 weeks ago, I got a little wild hair up my ass, b/c my friend started smoking the front tires of his RSX off.. (empty parking lot) SOoo.. I couldn't let him show me up. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'> I put it in reverse, and start rolling back at about 2-3 mph, put it back in first, run the rpm's up to about 4500-5000rpm, and let her rip, foot in the floor. It was a QUITE spectacular one leggeg smoke off. SPun through first, hit second and spun all the way through second, and then chirped 3rd. His jaw was on the floor in aww of the mighty peg legged power of the 240. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/nervous.gif" border="0" valign="absmiddle" alt=':nervous:'> lol <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
Old 05-10-2002, 02:04 PM   #5
AceInHole
Autox Technician
AceInHole's Avatar
yeah, but in my friend's '92 I did 2 burnouts.... both of them left completely equal length strips!!!!
I even held it still for a bit using the brake (left foot sidestep the clutch and get right on the brakes with the right foot floored on the gas, then lock the front wheels with as little braking as possible. fucks the rear brakes up, but uhh.... it's not that bad <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''> <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> ). &nbsp;I swear that car has VLSD...
Old 05-10-2002, 02:16 PM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''> &nbsp;I want vlsd...
Old 05-10-2002, 02:18 PM   #7
AceInHole
Autox Technician
AceInHole's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ May 09 2002,4:16)</td></tr><tr><td id="QUOTE"><img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''> I want vlsd...</td></tr></table><span id='postcolor'>
they're like $200 around here.... my friend got his for $230, and I've seen J30's as low as $150 ('95+ ).
I'd rather spend that on swaybars though <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
Old 05-10-2002, 02:36 PM   #8
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (AceInHole @ May 10 2002,4:18)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ May 09 2002,4:16)</td></tr><tr><td id="QUOTE"><img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''> I want vlsd...</td></tr></table><span id='postcolor'>
I'd rather spend that on swaybars though <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
I'm probably gonna get my swaybars as a present. &nbsp;so, I might spend the money on an LSD. &nbsp;I can't find one that cheap though. &nbsp;Always 300-350. &nbsp;The rear pinion seal on my Diff is leaking, so that'll give me a reason to just replace the whole thing. lol
Old 05-10-2002, 05:37 PM   #9
azboy
azboy is an unknown quantity at this point
the way to check if you really have LSD is to jack up both rear tires and spin one of them. &nbsp;if the other tire spins the same direction then you have LSD (or at lease that's how we did it for hondas, not sure for nissans)
azboy is offline   Reply With Quote
Old 05-11-2002, 12:40 AM   #10
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">sykik.... If you don't have HICAS then you don't have LSD.. UNLESS someone installed it afterwards.
</td></tr></table><span id='postcolor'> &nbsp;
er wrong it was an option on all years if the person ordered . I have been over this in the past in 89-90 Nissan paperwork shows the possibility of it being only availible with Hicas after 90 it was an option that could be ordered and you did not have to have HICAS to get . Me and Alex Chang have discussed this at length on the net and at Meets.
Dave
New Video
Buy my mounts!
Old 05-11-2002, 06:46 PM   #11
blink0r
blink0r is an unknown quantity at this point
Gotta love canadian s13's.... VLSD, hicas, abs. I got the whole deal. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
1991 Nissan 240sx SE
&quot;Friends don't let friends drive trucks.&quot;
blink0r is offline   Reply With Quote
Old 05-12-2002, 10:20 AM   #12
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (blink0r @ May 11 2002,8:46)</td></tr><tr><td id="QUOTE">Gotta love canadian s13's.... VLSD, hicas, abs. I got the whole deal. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
manual seatbelts, daytime running lights... &nbsp;(bitch)
