![]() Hey, Everybody. I have a acquired a magazine called. Sport Compact Car, Issue Volume 17 NO. 12. (It's got a big cover shot of a Skyline's rear. And Says "THE BOSS".) Well in this mag, on page 34. It says something like the trany for SR20's are weak and will break. (Here is as Direct a quote as possible).
"How much power do you want? One hundred seventy horsepower at the wheels naturally aspirated with tons of torque? QR25 is your engine. You want a turbo and ton of power? Stick with the SR20. The only problem with the SR20, and it's a big one, is that the transmission is horribly weak. Make much more than 200 hp at the wheels and the transmission will break." Now are they talking about the. S13,S14,S15-SR20's. Is this even a problem? Can the trany be strengthened? If so how? But above all, does anyone have anything to say about this? (Sorry if this has been brought up and answered. I looked, but could not find anything.) |
![]() Join Date: Jan 2004
b13/b14 sr20de. Also known as that which came in the Sentra se-r/200sx se-r/G20 and I think thats it. FWD buddy boy
Where are you at in Florida?
I'm from Florida so I'm probably a bit more strange than you |
I dont really know what they are talking about either to be honest. I have had two friends with GTI-R Sentra's and neither one of them had ANY problems and both dyno'd in the 275whp range
#6 |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Definitely FWD. I own one, I should know. If you search through sr20forum.com youll understand. The common cure for that is converting the newer hyraulic trannies from b15/p11 to cable, a few have survived more then 450whp. Anyway, its not a common problem for the rwd setups.
#8 |
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
yea the S chassis driveline is legendarly overly built. 400+hp, just not the S15 6 speed. Basically they took the same 5 speed housing and cramed another gear into it. The result is narrower gears and an overall weaker tranny.
#10 | |
![]() Join Date: Nov 2005
#12 | |
![]() Join Date: Dec 2002
![]() ![]() Feedback Score: 1 reviews
Life is good in the bay. |
#14 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
Don't forget your PAR sraight cut gears....thats what my buddy Ray got!!
#16 | |
True, but its not a cheap alternative. Think about it, we drive sentras haha. They have some issues also, but I dont wanna go OT. I assume your friend is on sr20forum?
#17 |
its fwd 91to98 fwd trannd can only hold 300hp tops,but if u get a b15tranny
lets just say no one has find the limit yet.a friend of mine with a neovvl hybrid swap i making 501whpand 350wtq at 15lbs.just stripped the clutch and the tranny was fine..after i saw that am thinking of going back to fwd |
#19 | |
Trader Rating: (58)
Yes he is (Rkawksi)....in fact I'm also personal friends with the owner of the forum (Matt) I used to be avid on the forums, but it's blocked over here by the airforce net nanny (as are the countless alternative URL's for the forum ![]()
#20 |
![]() Join Date: Aug 2003
sup cody! when you coming back to the States?!
for a FWD car making 350+, I'd think drivability is an issue...
U13 and S13 ![]() ![]() |
#21 | |
#23 |
most stock trannys are good tell around 400ish hp only sr20det tranny thats just junk is the s15 6 speed os giken sells the gears and shafts so youll have a almost bulletproof tranny
