Old 05-11-2002, 06:33 AM   #1
Roly
Nuclear
Roly is an unknown quantity at this point
I saw the weirdest thing,... my FSM says to use Dextron 3 ATF for my power steering. I asked a friend who has a Z31, and his FSM says the same for his. Have you checked to see if yours says this as well?
RACECAR spelled backwards still spells RACECAR
Roly is offline   Reply With Quote
Old 05-11-2002, 07:55 AM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
and the weird thing is?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
AceInHole is offline   Reply With Quote
Old 05-11-2002, 09:12 AM   #3
Roly
Nuclear
Using transmission fluid for the power steering... I wouldn't think that the steering systems gets that hot in which regular PS fluid isn't used.
Old 05-11-2002, 10:29 AM   #4
AceInHole
Autox Technician
AceInHole's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Roly @ May 10 2002,11:12)</td></tr><tr><td id="QUOTE">Using transmission fluid for the power steering... I wouldn't think that the steering systems gets that hot in which regular PS fluid isn't used.</td></tr></table><span id='postcolor'>
Since the power steering unit has gears in it, it would make sense to use fluid that would also lubricate as well as be used as an incompressible hydraulic fluid. &nbsp;Automatic transmission fluid can do this.
IIRC (but I think I'm wrong): normal power steering fluid isn't as lubricative as tranny fluid.
