Old 02-28-2002, 12:40 PM   #1
dsjunkie
dsjunkie is an unknown quantity at this point
ok i got a hold of a 91 kade and i want to drop it in my car....i want to save money so i want to do it myself....i have the chiltons on the 89-92 240 but to make things easier on myself i was wondering if anyone knows of a site or has one with specific detailed intructions on switching out the ka and the kad preferably with pictures maybe.....my searches on the engines have turned up fruitless so i'm turning you ya'll......thanks
dsjunkie is offline   Reply With Quote
Old 05-28-2002, 04:14 PM   #2
BadBoy
BadBoy is an unknown quantity at this point
I would also want that information <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> I will be doing this swap my self and i will like to know what parts of the ka24de i will need.
Thanks
BadBoy
BadBoy is offline   Reply With Quote
Old 06-01-2002, 12:24 AM   #3
BadBoy
Anyone know <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
BadBoy
Old 06-01-2002, 10:32 PM   #4
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
IF you have the engine and the ecu for the new engine that is all you need i belive cus you are only putting a newer engine in.you are going from a sohc to a dohc.I belive the wireing harness is the same cus they are the sme engine unless the engine is a auto but not likely.While you are taking thing apart why not put a newer clutch in you tranny so you can enjoy for a longer time.Unles you got real low miles.
BEISSEN is offline   Reply With Quote
Old 06-05-2002, 10:08 AM   #5
Twonius
Twonius is an unknown quantity at this point
I've also heard that you're gonna need the power steering lines from a ka24de, the pump was moved over to the other side. as for wiring i don't think there should be that much of a difference, and the block should still be the same as well.
Twonius is offline   Reply With Quote
Old 06-05-2002, 11:31 AM   #6
AKADriver
AKADriver's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Twonius @ June 05 2002,11:08)</td></tr><tr><td id="QUOTE">I've also heard that you're gonna need the power steering lines from a ka24de, the pump was moved over to the other side. as for wiring i don't think there should be that much of a difference, and the block should still be the same as well.</td></tr></table><span id='postcolor'>
The wiring is different. &nbsp;you need to modify the dash harness just like you would to drop an SR20DET in an SOHC, and you need the KA24DE wiring harness (but you can leave it unmodified). &nbsp;I think you also need the later fuse box and stuff.
The KA24E tach also won't work with the KA24DE.
Basically the swap is about as complicated as an SR swap into an SOHC. &nbsp;It's just a hell of a lot cheaper.
Old 06-06-2002, 06:06 AM   #7
BEISSEN
That is true about the power steering pump and lines but as far as the tach goes i belive you will be fine.Buti am not completly sure on the tach.
Old 06-06-2002, 11:10 AM   #8
geeaj
geeaj is an unknown quantity at this point
It isn't worth the trouble for 15hp unless you can get the swap parts and engine for really cheap.
Beware the fury of a silent man, be more cautious of his silent farts....
geeaj is offline   Reply With Quote
Old 06-07-2002, 08:03 PM   #9
AKADriver
AKADriver's Avatar
It's worth it if your KA24E is blown. &nbsp;But you're right, it's not a performance mod.
Old 04-06-2003, 06:08 PM   #10
weirdstyles.net
This guy...
weirdstyles.net's Avatar
weirdstyles.net is an unknown quantity at this point
Send a message via AIM to weirdstyles.net
See how old this **** is...
Im about to buy a KA24DE with 5 speed, but correct me if I am wrong, I will need the P/S pump, ECU, harness and tach?
****...this is more complicated that I thought...
My project car...
From dust you were born,
And to the ashes you return ~ Kill Switch Engage
Family Guy
Quagmire: Hey, how old are you sweet thang?
Connie: 16.
Quagmire: 18? Alllll-right!
Connie: Mommmm!
Quagmire: I like where this is going, Giggidy giggidy gig-gi-dy!
weirdstyles.net is offline   Reply With Quote
Old 04-08-2003, 06:34 AM   #11
driftk2000
driftk2000's Avatar
driftk2000 is an unknown quantity at this point
YOu got that rite Bud. You asked power steering pump????
DON'T FORGET THE POWER STEERING LINES off of the DOHC s13's.
I also heard elsewhere that the tachometer swap is also needed due to the DOHC and SOHC signals being different.
ANd when you install the harness and need help with advice, then come back to the Forums because it's been discussed here before.
Good luck Mon
driftk2000 is offline   Reply With Quote
Old 04-08-2003, 09:05 AM   #12
weirdstyles.net
This guy...
Notta noob here, beleive me I have tried the search and it is REALLY buggin me cause you cant use less than three letters....
but in reality....this blows. Lemme see if I can find a 91+ 240 with a blown motor and good body condition...
shiat
My project car...
Family Guy
Connie: 16.
Connie: Mommmm!
