Bent Subframe
Well anyways I was driving to SAT's on the day after it had snowed at about 7o'clock in the moring and ended up hitting some thick ass ice at about 10mph. I slid into a curb and unbalanced my tire, bent my rim, and apparently bent my subframe.
Anyways, I want to know if it is safe for me to drive with a bent subframe. It kinda pushed my wheel backwards in the well...giving it a nice little caster on the side that came into contact with the curb. (I'm 90% caster...I'm still learning...Leave me alone) Also, I would like to know a ballpark of what it would cost and if it's even worth fixing. Thanks for any help and any comments are welcome. Mods: I put this in off topic because this has to deal with a civic, and not a 240 in which I'm to poor to afford. Edit: Did some searching found that its an "easy" swap in a 240 but im still deciding if its going to be the same deal with a civic. RAWR Last edited by BrokenHeart; 12-10-2005 at 01:35 AM.. |
![]() Join Date: Apr 2003
last time i checked civics didnt have subframes. they had independent rears?
nywho, its a good idea to get your car onto a rack to see if your frames been shifted or not.
LP stylez!! bishes Lazy Penguin since teh 04' ![]() ![]() ![]() Part of the Elite Shasta Speed Stars RIP......05-09-03....*sniff sniff ![]() the beast nears completion..... ![]() YOU LOOK AND U BUY STUFF !!!!! |
![]() Join Date: Feb 2005
well if they cant align it properly, its pretty much fucked. you cant take the subframe out of a civic, as it is welded into the car. basically...either drive it with bad alignment, or get rid of the car and get a 240 haha
pulling outta the game: http://www.zilvia.net/f/showthread.p...wpost&t=119867 parting out, just let me know. |
![]() Join Date: Sep 2003
i highly doubt that ur frame is bent majorly, more then likely ur suspension arms might be... so check those and if ur civic is pre 95 more then likely u can find parts at a pick n pull locally
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
