Old 05-11-2002, 07:05 PM   #1
jdematt
jdematt is an unknown quantity at this point
anyone know how to paint the interior plastic pieces? i have mine covered with a carbon-fiber plastic thats head-gunned on, but i want to paint it white. anyone know how to prep the plastic or how to go about the whole process in general?
jdematt is offline   Reply With Quote
Old 05-11-2002, 07:39 PM   #2
SR20Fastback
SR20Fastback is an unknown quantity at this point
Send a message via AIM to SR20Fastback
Couple coats of krylon primer and then a couple coats of krylon flat white. You can buy them at shucks for about 4-5 dollars a can.
Fodive STILL blows goats, I have proof.
SR20Fastback is offline   Reply With Quote
Old 05-11-2002, 08:34 PM   #3
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
make sure to prep it by THOROUGHLY CLEANING the trim with alchohol or some strong cleaner/ degreaser of sorts.  If you have armorall on there, the paint will NOT STICK.
You've been warned!!
good luck!
AceInHole is offline   Reply With Quote
Old 05-11-2002, 10:47 PM   #4
240licious
240licious is an unknown quantity at this point
make sure you paint it in a clean area.  i did mine in a garage and i cant tell you how many times i had to redue some pieces because of the dirt in the air.
One time a small gnat flew in front of my paint can and he got stuck on one of my interior pieces and that piece was almost done...just watch out for them bugs! and get ready for a big headache
98 SE 5spd Ultra Red
240licious is offline   Reply With Quote
Old 05-11-2002, 10:54 PM   #5
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
just carbonfiber it, it's fun, trust me...  just look @ my strut bar
only took me 7hrs of fun! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cool.gif" border="0" valign="absmiddle" alt=''>
240meowth is offline   Reply With Quote
Old 05-12-2002, 12:05 AM   #6
Kaede
Kaede is an unknown quantity at this point
Send a message via AIM to Kaede
Use flat white and not gloss white. Primer is not really necessary. But I think you should spray one or two coat of clearcoat though. And like Ace said, clean the piece well.
If you can, take the piece off your car to spray. Try not to mask stuff.
The last thing I want to say is don't spray the plastic trim on the outside of the cluster gauges white. During a sunny day, the trim can produce a very nasty glare and make it hard to read your gauges. Oh, and basically anything you spray that will be horizontally positioned will produce a glare on your windshield.
Kaede is offline   Reply With Quote
