Old 12-16-2005, 09:10 AM   #1
nissantuner22
nissantuner22's Avatar
Trader Rating: (-1)
nissantuner22 is on a distinguished road
Feedback Score: -1 reviews
Send a message via AIM to nissantuner22
Safely Reuse Flywheel Bolts?
Simple question. I was always under the impression bolts like that were not supposed to be reused, due to being nearly torqued to yield. I think my old marine mechanics teacher preached that more than anyone I've heard. I'm replacing the clutch in my SR, and I'm wondering ,is it necessary to replace them, or are they reuseable? If I need new ones, whats the cheapest/ fastest way to get them? (if the dealer is way to expensive compared to online) A search yielded no useful information. Appreciate it guys!
Current Project: Operation: N/A SR: 93 Silvia Q SR20DE Engine with go fast goodies. ,
"Common problems 240sx's suffer from are curbs, trees, ditches, and other immovable objects."thx247
"on the tounge... there is no guardrails."- citizen
nissantuner22 is offline   Reply With Quote
Old 12-16-2005, 11:00 AM   #2
aznpoopy
aznpoopy's Avatar
really? on two jobs i did i reused the old bolts. damn... :X
aznpoopy is offline   Reply With Quote
Old 12-16-2005, 11:50 AM   #3
240sxconversion
240sxconversion is an unknown quantity at this point
i wouldnt reuse them, just my .02 cents.
Current project is a rb30DETT or DET http://members.cardomain.com/240sxdrifter04
240sxconversion is offline   Reply With Quote
Old 12-16-2005, 12:13 PM   #4
reactor
reactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nice
The bolts for the SR flywheel aren't torque to yield. They're just torqued to 94-101 ft lbs. Torque to yield bolts are when you torque the bolts and then turn them an additional x number of degrees. Also the FSM does not say to replace them after each use.
reactor is offline   Reply With Quote
Old 12-16-2005, 01:43 PM   #5
sdtouge
sdtouge can only hope to improve
are you removing the flywheel?
if not then dont even worry about it. changing the clutch you dont need to drop the flywheel unless you are doing pilot bearing or rear main seal.
sdtouge is offline   Reply With Quote
Old 12-16-2005, 02:13 PM   #6
aznpoopy
aznpoopy's Avatar
you should always replace the pilot bearing during a clutch job.
Old 12-16-2005, 07:32 PM   #7
go240
go240 is on a distinguished road
you should also get the flywheel resurfaced
i reused mine
go240 is offline   Reply With Quote
Old 12-16-2005, 08:05 PM   #8
mrmephistopheles
mrmephistopheles's Avatar
You can reuse them with no problem.
Originally Posted by PHLIP
Old 12-16-2005, 08:13 PM   #9
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
u can, but sometimes those daymn things can never come out....
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
