Old 12-24-2005, 12:39 AM   #1
logistixz
logistixz is an unknown quantity at this point
sr20 swap problems
ok i just finished dropping the sr into my 1992 240sx coupe and hooked everything up and wired it all accordingly to ht's wiring diagrams. the motor turned over fine but it wouldnt catch, itd catch a few times but just die out or buck and hiccup and die. i have spark and fuel and the injectors are firing i cant figure out what the problem would be, also the cam/crank angle sensor is all in one? could it possibly be the coolant temp sensor? i dont recall hooking a coolant temp sensor up (location)? all help is greatly appreciated
logistixz is offline   Reply With Quote
Old 12-24-2005, 08:24 AM   #2
logistixz
bump
Old 12-24-2005, 10:25 AM   #3
skiboard06
skiboard06 is an unknown quantity at this point
keep trying it when i started my motor it took a long while of cranking to get the motor to turn over these have been sitting for a longgg time and arent gunna just start right up
skiboard06 is offline   Reply With Quote
Old 12-24-2005, 09:37 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Temp sensor is right on top of the lower water neck. Go tru the usual checks: Compression, timing, sparkplugs, sticking fpr, leaky injectors.
CLICK HERE!!!
Old 12-25-2005, 02:41 PM   #5
240SX714
240SX714 is a jewel in the rough240SX714 is a jewel in the rough240SX714 is a jewel in the rough240SX714 is a jewel in the rough240SX714 is a jewel in the rough240SX714 is a jewel in the rough240SX714 is a jewel in the rough
It starts fine, but then it dies? Any smoking or puffing? Try checking for pressure leak in your system.
240SX714 is offline   Reply With Quote
Old 12-26-2005, 03:13 AM   #6
SRd240sx
SRd240sx's Avatar
SRd240sx will become famous soon enoughSRd240sx will become famous soon enoughSRd240sx will become famous soon enoughSRd240sx will become famous soon enough
Send a message via AIM to SRd240sx
check timing. was it messed with? was the CAS removed?
SRd240sx is offline   Reply With Quote
Old 12-26-2005, 04:01 AM   #7
blu808
blu808's Avatar
Water temp sens wont effect it starting. I would reset the cas first. It sounds like the cas is outa line. Then i would make sure that the tps is reading properly. The tps shouldnt effect start up but it can in some cases.
Also keep this is mind. There is a wire out of the ecu that is used to change the timing and fuel when the motor is at startup phase. Please make sure that wire is hooked up. Sorry i dont have more info on it. but it basically makes the injectors act like a cold start injector.
Old 12-26-2005, 10:11 AM   #8
logistixz
perfect info i reset the CAS and it started right up but now the damn thing is running rich as hell. it doesnt seem to have any power in the midrange and seems to be boosting real low (im using the stock sr20 vacuum line with the orifice/restrictor in it connecting it to the stock cold pipe) and like you said coming out of my ecu there are these three wires from right near the self diagnostic area (red/black/white) and i have no idea what they do. i just cant figure out the bucking now around the midrange and i used shielded wire for the MAF sensor and the o2 sensor. all help is greatly appreciated guys!
Old 12-27-2005, 10:10 AM   #9
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
Sounds like you have a boost leak somewhere now.
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 12-27-2005, 06:31 PM   #10
logistixz
i checked that too but everything is real tight, i pulled the entire stock sidemount system off the front clip and just put it onto the car i checked it over and checked it over again but i dont see any areas where a leak could be
Old 12-28-2005, 01:45 PM   #11
ziden
ziden is an unknown quantity at this point
It sounds like you have a boost leak becaue its is loosing PSI and breaking up. Did your clip come with fenders? If not it may be damaged in shipping.
ziden is offline   Reply With Quote
Old 12-28-2005, 04:35 PM   #12
logistixz
i figured it out guys, apparently what i believed was true the ecu i had gotten with the motor was chipped and wasnt tuned correctly for the stock setup (which is what the harness coming out of the ecu was probably for switching maps, or datalogging or something). i swapped ecus with a known stock redtop ecu and the car now runs like a champ!
Old 12-28-2005, 10:15 PM   #13
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
good deal........... like a champ good going guy
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
