Old 12-28-2005, 11:00 PM   #1
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
ka 5spd tranmissions?
ok i know all 240 tannies will work with each other, but is there any other nissan transmission that will bolt up to the 240sx ka and work, IE nissan harbody truck, they are like a dime a dozen at the local salvage yards and findin a 40 trans is like tryin to find a needle in a hay stack so i was curious if any other trans would work, or maybe likea hybrid, ka bell housing on a 300zx trans or somethin else that might work. thanx hope someone can help out!
sil80forme is offline   Reply With Quote
Old 12-28-2005, 11:24 PM   #2
IGSDann
IGSDann's Avatar
IGSDann is an unknown quantity at this point
AFAIK you'll at least need a 5 speed 240 bellhousing... SR trannies are the same as KA's, they just have different bellhousings. I imagine the hardbody would work as it's a KA and maybe something from a 200sx (which has the CA18ET and is RWD) otherwise I don't know...
Pushing 14.7 PSI of all natural boost!!!
IGSDann is offline   Reply With Quote
Old 12-29-2005, 12:06 PM   #3
skiboard06
skiboard06 is an unknown quantity at this point
arent 91+ 300zx trannies the same?
skiboard06 is offline   Reply With Quote
Old 12-29-2005, 12:07 PM   #4
Dousan_PG
Dousan_PG's Avatar
no they are definitely not
Aaron
Pink GodziRa
Old 12-29-2005, 12:20 PM   #5
projectRDM
projectRDM's Avatar
Autos, yes. But with a different bellhousing. Manual, not even close.
FORMERLY R240NA
Old 12-30-2005, 08:46 AM   #6
pr240sx
pr240sx is an unknown quantity at this point
280/260 zx
Nissan Pickups
Are exactly the same (bellhousings and internals)
Older tranny does not use an extra sensor (neutral sensor I think)
pr240sx is offline   Reply With Quote
Old 12-30-2005, 02:02 PM   #7
sil80forme
sil80forme's Avatar
trans
i thought the truck transmissions were a lil shorter? does anyone know how much longer the auto driveshaft is then the manual one or its total length all together, i have a spare driveshaft but i dont know whichj one it is i have had somemany differnet ones i cant keep track.
Old 12-30-2005, 03:49 PM   #8
pr240sx
Dunno what years in specific
I am using right now a nissan truck manual tranny (I think that is 87 or 88)
I can dig up a pic with the two trannys side by side.
I didnt note any difference in lenght (or weight!)
One thing though, the current one DOES NOT have one sensor and does not provide a boss so you can install it. My reverse and 4th and 5th gear sensors are present (disconnected) and work just fine.
Old 12-30-2005, 04:58 PM   #9
sil80forme
sil80forme's Avatar
kew thanx
