Old 01-14-2006, 03:12 PM   #1
junks13
junks13 is an unknown quantity at this point
jdm cluster question
i have a 91 coupe with hud and iwant to install a jdm cluster what do i have to do i already have the cluster
junks13 is offline
Old 01-14-2006, 03:30 PM   #2
S14DB
AFC #1
S14DB's Avatar
Um, Install it?
S14DB is offline
Old 01-14-2006, 03:32 PM   #3
junks13
you put it in my dash were my stock one is now
junks13 is offline
Old 01-14-2006, 03:44 PM   #4
projectRDM
projectRDM's Avatar
Where else would you put it, in your ass?
FORMERLY R240NA
projectRDM is offline
Old 01-14-2006, 04:39 PM   #5
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
these guys are dicks. It will plug up to the original plug. No mods necessary. Just drop the knee blocker, then the steering collumn. next remove the bezel then gauge assembly, install is reverse.
RedtopTech is offline
Old 01-14-2006, 04:45 PM   #6
g6civcx
g6civcx's Avatar
Yes, it's very important to drop the steering column. You'll need a 12mm deep well socket to get at it. Don't try to remove the cluster w/o dropping the column because you will damage it.
Just remember that it will show kilometres for odo/speedo instead of miles.
g6civcx is offline
Old 01-14-2006, 05:22 PM   #7
junks13
thanks alot dudes but the guy i got it from had a 90 240 with an sr20 and he said somthimg about using my tach i dont know much about electrical stuff
junks13 is offline
Old 01-14-2006, 05:34 PM   #8
g6civcx
g6civcx's Avatar
SOHC tach will only work with SOHC. DOHC tach will work on any DOHC, KA24DE or SR20DET. He wants your tach probably because he's swapping in a DOHC motor.
g6civcx is offline
Old 01-14-2006, 05:41 PM   #9
junks13
no he dont want my tach he said i could use it in the jdm cluster because the one he gave me came out of his and he used to have a sohc
junks13 is offline
Old 01-14-2006, 05:47 PM   #10
g6civcx
g6civcx's Avatar
The JDM cluster came from an SR clip, correct? If so, the tach work on your DOHC car.
If the tach came from his SOHC car, then no it will not work with your DOHC.
g6civcx is offline
Old 05-29-2007, 11:07 PM   #11
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
h/o. i didnt think there were any sohc jdm s13's? r there?
sr20et
ca18et
doesnt sound right
jskateborders is offline
Old 05-29-2007, 11:11 PM   #12
johngriff
johngriff's Avatar
I think we are trying to find specificity in which guage cluster he infact does retain.
Are you getting rid of your hud because it is broken? I'll buy it for $18 shipped in a USPS flate rate box. Hit me up!
John
[email protected]
[email protected]
johngriff is offline
Old 05-30-2007, 08:43 AM   #13
projectRDM
projectRDM's Avatar
1.5 year old thread.
FORMERLY R240NA
