Noob here with a question
Hey guys I'm picking up a 180sx from calli in three but I got this question to ask you. I found a sr20de from one of my friend who is selling to me but how hard is it to turbo it and what do I need also can I put some sr20det parts on the sr20de. Any help will do also what is the compression on the sr20de.
![]() Join Date: Feb 2005
Since you are thinking of swapping in a USDM SR20DE into your "180sx" I'm guessing you are not really getting a JDM 180sx, but rather that you think you will impress us by using "180sx" instead of the proper name, 240sx.
Your questions can be EASILY answered by doing a simple 1 word search. It would be in your best intrest if you use the search butotn in the future. Since you are a noobie, Ill get you going in the right direction: LOTS of threads to pick through http://www.zilvia.net/f/search.php?searchid=604355 Just 2 of the posts on the first of many pages that will probably answer a lot of the questions you have: http://www.zilvia.net/f/showthread.p...ghlight=SR20DE http://www.zilvia.net/f/showthread.p...ghlight=SR20DE EDIT: found another one... SAME scenario as you, and 2 pages of info: http://www.zilvia.net/f/showthread.p...ghlight=SR20DE Next time, please search before posting something that has been discussed MANY times before. Welcome to Zilvia. |
#3 | |
#5 |
![]() Join Date: Mar 2003
an sr20de is NOT the same thing as a sr20det
an sr20de with sr20det turbo parts slapped on it is still not the same thing as a sr20det. i think you need to do a little research on differences between the two engines. compression is higher on the sr20de then on the sr20det, as you would expect. |
#6 |
![]() Join Date: Nov 2004
Why are you purchacing a car and the first thing you worry about before you even purchace it is a swap? Being a nub is no excuse for stupidity. EVEN IF you get a sr20de it's not even close to a sr20det.
The DET has oil squirter piston coolers The DET has a bigger oil pump. The DET has a different front pulley. The DET has lower compression pistons (8.3:1 vs 9.5:1). The DET has bigger injectors. The DET has direct ignition. The DET has a variable intake cam, runs retarded at idle, advanced mid range and retarded top end. The DET has mechanical shim in bucket type lifters with a slightly bigger in duration exhaust cam.
#7 | |
SR20DE does NOT = SR20DET, as stated above. no mater what you do to it. |
#10 | |
you can do the sr20de and put on a turbo, it is the same setup i have, its cheaper than a sr20det... but it has plenty of disadvantages. you really need to search on this shit |
