Old 01-15-2006, 05:18 PM   #1
papa
papa is an unknown quantity at this point
Send a message via AIM to papa
SR Sr related power steering pump question??
Does anyone know if a KA pump will work on an Sr?? I know i a guy in my area who is running a KA pump on an sr but it leaks...i was wondering if anyone had an experience running one??
muAh
papa is offline   Reply With Quote
Old 01-15-2006, 07:25 PM   #2
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
yes, they are the same thing, if it is leaking... something is wrong with the pump
nsn240 is offline   Reply With Quote
Old 01-15-2006, 08:06 PM   #3
McRussellPants
Its leaking because he screwed up the crush washers.
The KA Pump will work but the bracket will not.
Does anyone know what will work / where to get an SR Powersteering Pump Bracket? Phase2, SRStore and Heavy Throttle say they're really hard to find.
Does the Hicas bracket work with a regular pump?
Does the FWD bracket work?
McRussellPants is offline   Reply With Quote
Old 01-15-2006, 11:37 PM   #4
papa
cool thanks guys...i will look tomorrow to see if the Hicas bracket works with a regular pump, my buddies got one laying around the garage
muAh
Old 01-16-2006, 02:33 AM   #5
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
not too sure if anyone sells the brackt, but it does pop up on ebay once in a while... the other option is the junkyard.
the pulley also needs to be swapped with the sr one.
and it's leaking because of faulty washers or the bolts were not lined up correctly.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 01-16-2006, 03:29 AM   #6
andrewmp6
andrewmp6 can only hope to improve
email http://www.pandagarage.com/ or try a fwd sr20de one it might fit youll have to find a sentra in a junkyard tho
andrewmp6 is offline   Reply With Quote
Old 01-16-2006, 08:02 AM   #7
Angel
Angel is making a name for him/her selfAngel is making a name for him/her selfAngel is making a name for him/her self
Just fyi, I have 2 complete sr power steering pumps and brackets for sale.
S13 redtop 2871R.64 377 rwhp 322 rwtq
11.5 @ 117
Angel is offline   Reply With Quote
Old 01-16-2006, 11:37 PM   #8
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
the KA Pump is the same but bracket and pulley need to be from RWD SR20DET.
kazuo is offline   Reply With Quote
Old 01-17-2006, 12:44 AM   #9
papa
thanks alot for the info guys
muAh
Old 01-19-2006, 06:51 PM   #10
sushimonster
sushimonster is an unknown quantity at this point
i have a non hicas s13
im doing a swap and i have the hicas pump for the sr
do i need the complete non hicas pump( bracket/pulleys)
or i just need the main ps pump????
sushimonster is offline   Reply With Quote
Old 01-19-2006, 11:51 PM   #11
kazuo
You need the NON-HICAS pump & pulley.
Read the FAQ next time...
Old 01-20-2006, 12:46 AM   #12
sushimonster
i think i missed that part in the faq... thanks alot thou
Old 02-22-2006, 06:32 PM   #13
jaae86
jaae86's Avatar
jaae86 will become famous soon enoughjaae86 will become famous soon enoughjaae86 will become famous soon enoughjaae86 will become famous soon enoughjaae86 will become famous soon enough
Send a message via AIM to jaae86
I have a busted SR ps pump. So basically, remove the pulley and bracket from the sr pump and put it on the KA ps pump? Are all the lines in the right location for the KA ps pump? Thanks for any info.
Jeff Andrade
myspace.com/jeffandcrisandrade
jaae86 is offline   Reply With Quote
Old 02-23-2006, 12:35 AM   #14
kazuo
Correct Jeff.
Good luck
