Old 01-16-2006, 06:16 PM   #1
Ess14
Ess14 is an unknown quantity at this point
Windshield Wipers don't turn off.
My windshiled wipers have issues.
The knob adjusting speeds does not control anything, and the only speeds it knows are fast and very fast.
Also, once I turn my wipers on, they will not go off, they will change speeds, but when I move the switch they don't turn off.
They do go on when I activate the wiper fluid.
Could this be a switch issue? Any thoughts...
Ess14 is offline   Reply With Quote
Old 01-16-2006, 06:19 PM   #2
projectRDM
projectRDM's Avatar
Probably the wiper amp.
You're just determined to fly me up and fix all this shit, aren't you?
FORMERLY R240NA
Old 01-16-2006, 08:03 PM   #3
RyanA96
RyanA96 is an unknown quantity at this point
I have the exact same problem. Before I installed my SR it worked fine, now it don't. Don't know whats wrong either.
Subscribing
RyanA96 is offline   Reply With Quote
Old 01-17-2006, 09:19 AM   #4
g6civcx
g6civcx's Avatar
+1. R240NA is a stud...
Old 01-19-2006, 03:29 AM   #5
mikeeonfiya
mikeeonfiya is an unknown quantity at this point
there is a demon controlling your wipers. this calls for an exorcism
mikeeonfiya is offline   Reply With Quote
Old 01-19-2006, 04:26 AM   #6
blk90s13
blk90s13 is an unknown quantity at this point
Send a message via AIM to blk90s13
make sure the motor is grounded right ( wiper motor )
Signature goes here
blk90s13 is offline   Reply With Quote
Old 01-19-2006, 12:36 PM   #7
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
i had the exact same problem and the problem was simple, when you guys were pluggin in the wiper module to the harness make sure you didnt bend any of the pins inside the module, i had 1 pin out of place then when i plugged in the module it bent it even more so there was no connection on one pin. i suggest you guys unplug the module and just take a look. i found one bent and just got a flathead and straighten it, now it works fine
hope that helps u guys
henry
kouki_s14 is offline   Reply With Quote
Old 03-08-2006, 02:48 PM   #8
Ess14
Old thread, but today I got around to it haha.
I located the wiper amp and I unplugged it.
Now they turn off but the intermittent wipers don't work... As expected when I remove the amp - But I didn't realize that the other two speeds would work correctly and that it would turn off when I put the lever back in the off position.
I plugged it back in and once again it does the same thing stated before.
The amp is doing something...
(I think).
Could this still be a bad amp somehow or what might the issue be?
(Checked all prongs, they look good).
Thanks
Old 03-08-2006, 06:45 PM   #9
projectRDM
projectRDM's Avatar
It's still the amp. The amp controls the intermittent setting, if damaged it will allow for current to run continually to the motor.
Old 03-08-2006, 06:50 PM   #10
g6civcx
g6civcx's Avatar
This happened to me as well. It was a bad fuse in my case.
Old 03-08-2006, 07:02 PM   #11
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
Switch the relay with another known good one.
RedtopTech is offline   Reply With Quote
Old 04-04-2006, 04:17 PM   #12
DoriftoPnoy
DoriftoPnoy's Avatar
DoriftoPnoy is on a distinguished road
hmmm... so where's the wiper amp? All i can do to turn mine on is switch it to the highest speed and then when I turn it off it won't go back all the way down. It will just stop right where it is. 0.0
DoriftoPnoy is offline   Reply With Quote
Old 04-04-2006, 04:34 PM   #13
g6civcx
g6civcx's Avatar
Left or right strut tower depending upon equipment, towards the rear of the car. Download an FSM from zeroyon.com and look for it in the EL section.
Old 04-04-2006, 04:38 PM   #14
projectRDM
projectRDM's Avatar
There is no wiper relay. Good shot at giving shitty information.
Old 04-04-2006, 04:41 PM   #15
g6civcx
g6civcx's Avatar
Pink for a reason
Old 04-04-2006, 06:18 PM   #16
Ess14
Dorifto this is 99% a bad wiper amp or no amp at all.
Same symptoms as when I run no amp.
The wiper amp plug will probobly be (when looking at the engine bay) on the left of the motor in the back corner. Look down in there for a bit it's a 3 prong plug and the amp itself is brown if you even have one in there.
If this has been the problem ever since you bought the previous owner might actually not have an amp in there.
~I fixed the original problem, bought an amp from R240, works like new.
