Does anyone make Urethane Subframe bushing collars??
My S14 comes up w/ common problem..
when you shift, rear subframe makes sound.. But then, If I just put in Subframe bushing collars, I don't need to change subframe bushings right? I've been reading posts here whole day.. I use my car for track/also daily so aluminum sounds hard core for me. So, I'm looking for Urethane Subframe bushing collars..but can't find it anywhere. Can anyone help me out? |
#5 |
I have the Whiteline ones. Takes minutes to install. A little difference but I still expreience wheel hop now and then.
#6 | |
![]() Or this one? ![]() Pdm-racing says it's Rear Nissan Sub-Frame Align and Lock Kit.. Also, If I get spacers, I don't need subframe bushings right? Thank you guys.. |
#8 |
If you don't want spacers but want urethane bushings, look into Peak Performance like TurDz said. Here is a link that came up in google...
http://www.store.yahoo.com/phase2mot...epeursubu.html |
#9 | |
![]() Join Date: May 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Oh, so you have to remove the old rubber bushings to put in the Peak Performance ones? I had no idea... The PP ones are shaped just like solid metal subframe spacers (Kazama, T3, ebay style) and I thought they slip on like the rest. guess not?
#10 | |
#11 |
I have the Whiteline ones on my hatch. Noticed improvement on traction and the rear feels a bit higher. Still have some hop though.
A friend has HEs and alluminum collars (nice and stiff) and likes the ride just fine. -Juan |
#12 |
I got Tein SD and after i put on the spl collar kit, i can't even tell you the difference it made. My back end is actually sticking to the ground. To ass-out, I have to actually clutch kick, or brake initiate. While before, I could just turn the wheel and press gas and the back end slid out.
#13 |
![]() Join Date: Jun 2003
just get the aluminum ones like everybody else. seriously you will hardly be able to tell a difference much less loose any ride quality. putting subframe collars on an old bushing is like the same as having brand new factory bushings (kindof?).
#14 |
![]() Join Date: Mar 2005
tanabe discontinued theirs
but yeah, other options as listed above aluminum is better imo, but either does the job
![]() A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan ![]() ![]() ![]() |
#15 |
If you have a broken OEM bushing in your subframe. Bushing collars/spacer will not fix the problem. You need to press/cut out your old bushings and replace with OEM ones or ES bushings. This is the problem I'm having right now. I installed the spacers on my subframe, a month later; one of my oem bushings broke. I can now move my subframe with my hand lol.
![]() driftingisgay.com |
#19 |
![]() Join Date: Aug 2003
Are these SCCA legal? I'm not sure about the aluminum ones either. It would suck if you're put in a higher class like Unlimited just because you have subframe collars/spacers
Petition Nissan to Make the IDx on http://IDxClub.co ! |
#20 |
AFC #1
![]() Join Date: Oct 2003
I got these Nylon ones off ebay for cheap:
![]() ![]() ![]() Unless you get the Aluminum ones with Notches cut out. You have to drop the whole sub-frame. Which is easy if you know the trick to it.
#21 | |
I'm looking for bushings now, but it seems everyone makes only spacers. I can't find it even in ebay. Can anyone give me a link for urethane subframe bushings for S14? Thank you |
#22 | |
#23 | |
what I want is "urethane subframe bushing" which is inserted into subframe. Sth that I have to remove stock old bushings to put in new "urethane subframe bushing" I don't want spacers for now.. Splparts.com doesn't have one. I thought this was it http://www.store.yahoo.com/phase2mot...epeursubu.html but I guess it's just like spacers? |
#26 |
AFC #1
Nismo makes replacement bushings. You have to take the sub-frame completely off the car with everything off. Then press out the old sleeves and press in the Nismo units. It's a major operation.
Most peoples bushings get soft after time and why they get the spacers like I have to reduce the slop. The whiteline bushings are to change the angle of the sub-frame to change the squat characteristics of the IRS. Unless your stock bushings are so shot to the point were the center pin doesn't stay in. I would get spacers to stiffen it up.
