Old 01-19-2006, 08:11 PM   #1
matt87
matt87's Avatar
matt87 can only hope to improve
Pick one:Oil temp or Oil pressure
I have a 3 gauge pod above my cd player and i have boost and water temp in there and one empty. I have a greddy oil filter relocation kit on the way and it has spots for either a oil temp or pressure gauge. I was thinking pressure but i just wanted to see what the rest of you think. What is the normal oil pressure or allowable range for an sr.
matt87 is offline   Reply With Quote
Old 01-19-2006, 08:21 PM   #2
McRussellPants
Oil Pressure for sure.
On my motor I usually do 1~1.2kgf at 800rpm fully warmed up. then 3.5~4 at 3000rpm and 5.5+ at anything over 4000RPM.
Thats on 15W-50
McRussellPants is offline   Reply With Quote
Old 01-19-2006, 08:26 PM   #3
g6civcx
g6civcx's Avatar
+1 for pressure. It's much more important than temperature.
Old 01-19-2006, 08:36 PM   #4
Dousan_PG
Dousan_PG's Avatar
pressure for sure!
no pressure is no good
oil temp. id get one too kinda go hand in hand. but id go for a pressure before temp if i were u
i run both...so..
Aaron
Pink GodziRa
Old 01-19-2006, 08:58 PM   #5
matt87
matt87's Avatar
I know that no pressure is no good but is there a to high of pressure?
thanks for the advice guys
Old 01-19-2006, 09:08 PM   #6
matt87
matt87's Avatar
hey dousan do you run an water temp guage as well?
If you do what are you water temps vs your oil temps?
Old 01-19-2006, 10:35 PM   #7
Dousan_PG
Dousan_PG's Avatar
all defi bf
boost
oil press
oil temp
water temp
water temp..80 range, oil temp 90 range (Celcius)
when i install the oil cooler and greddy pan should drop dramatically.
temp for oil on sandwich adapater
temp for water on the upper hose
Aaron
Pink GodziRa
Old 01-20-2006, 10:43 AM   #8
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
yes there is "too high a pressure" if the pressure is too high the seals will shoot out and gaskets will give up and all your oil pressure will turn into no oil pressure and a big mess on the ground.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 01-19-2006, 09:12 PM   #9
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
I run both. Pressure is more important though.
DJPimpFlex is offline   Reply With Quote
Old 01-19-2006, 09:46 PM   #10
1mns13
1mns13's Avatar
1mns13 is an unknown quantity at this point
Pressure for sure. It is more important than the temp.
www.the-nissan-240sx.com
1mns13 is offline   Reply With Quote
