Old 01-20-2006, 12:08 PM   #1
s13_gearhead
s13_gearhead's Avatar
s13_gearhead will become famous soon enoughs13_gearhead will become famous soon enoughs13_gearhead will become famous soon enough
Send a message via AIM to s13_gearhead Send a message via MSN to s13_gearhead
misc. issues, 93 s13 coupe
Okay, so I'm having a bit of a problem with the car I've got right now.. I bought it with an automatic transmission, and something was definitely wrong. The car wouldn't shift out of first gear until almost 6k rpms, and when it did it shifted very hard (obviously), chirped the tires, and wouldn't shift at all out of second. When I let off the gas and applied the brake at stop signs/lights, the rpms would drop down so low the car would die.
So I tore the automatic tranny out and installed a 5spd, I've done the swap a bunch, and it turned out fine. Car shifts and drives fine, but recently it's been doing the same thing as before, when it had the auto tranny in it - rpms will drop down significantly when I clutch in, almost always below 500, and sometimes the car will die. I checked for proper timing, and proper idle, everything seems fine.
Anyone have any ideas on why the car is losing idle when it's clutched in and braking? I cannot figure it out.
s13_gearhead is offline   Reply With Quote
Old 01-20-2006, 04:41 PM   #2
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
sounds like an IACV problem. Did you check that?
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 01-21-2006, 06:24 AM   #3
andrewmp6
andrewmp6 can only hope to improve
yeah its sounds like the idle air is messed up
andrewmp6 is offline   Reply With Quote
Old 01-21-2006, 03:47 PM   #4
s13_gearhead
Okay, thanks for the input, I'll check it.
