Old 01-21-2006, 03:19 AM   #1
91ka
91ka is on the path to ruin91ka is on the path to ruin
s13 look what ive found..
took a look at the upper chain guide today and it was literally sitting on top of the chain........... :hammer: has it happen to anyone else before? after pulling this out, idling didnt fluctuate anymore.
also, i have the grey rtv sealant and was wondering is that good enough for a 240 heat range? because i went to a shop and they were using another product (RTV) which took almost up to double the heat range. (it wasnt the blue RTV) they called it "the special formula" lol. i asked but they wouldnt tell me what it was.
91ka is offline   Reply With Quote
Old 01-21-2006, 03:22 AM   #2
neilsan
neilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-known
That guide breaks on just about every KA. A search will yield the information that Nissan themselves instructs their technicians to discard the guide between the cam gears.
I don't know what heat range grey rtv is for, for a valve cover its probably ok. Do yourself a solid and go buy a tube of Nissan brand gasket sealant from the dealership. I think its like $20 but itll last a good while and it's awesome. i use it for other cars all over the place.
neilsan is offline   Reply With Quote
Old 01-21-2006, 11:56 PM   #3
Chinoliro
Chinoliro's Avatar
Chinoliro is an unknown quantity at this point
same thing happened to me
just remove it
put a new gasket
done
Chinoliro is offline   Reply With Quote
Old 01-22-2006, 12:42 AM   #4
S13 Charlie
S13 Charlie's Avatar
S13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura about
Send a message via AIM to S13 Charlie
crazy! I'm actually going to remove mine tomorrow, I just hope it isn't already broken..
S13 Charlie is offline   Reply With Quote
Old 01-22-2006, 02:47 AM   #5
91ka
are there cases when the side guides are broken too? my tensioner isnt working right now and so the chains hitting the side guide time to time. hope it doesnt break by the time i get to the tensioner...
also when does the tensioner tighten and loosen? harder u accelerate the more tighten it gets and viseversa?
Old 01-22-2006, 03:07 AM   #6
matt87
matt87's Avatar
matt87 can only hope to improve
Anyone have a picture for reference?
matt87 is offline   Reply With Quote
Old 01-22-2006, 03:44 AM   #7
nistech
nistech will become famous soon enoughnistech will become famous soon enoughnistech will become famous soon enoughnistech will become famous soon enough
Send a message via AIM to nistech
http://img25.imageshack.us/img25/460/picture6rk.jpg
same thing happened to me about 3 weeks ago here is the pic.
nistech is offline   Reply With Quote
Old 01-23-2006, 12:21 AM   #8
S13 Charlie
Well, I finally removed the timing chain guides and freed up the tensioner. My guides were actually not all that bad, but it's oh so nice to not hear the diesel truck sound when my engine is idling.. Overall the hardest part for me was convincing the front cover to come off. I ended up buying a hammer and tapping it off "gently." heh.
The side chain guide looked to be in better shape than the upper one, so I think you have a little bit of time before that one goes, but don't sit on it man, get that thing outta there!
Old 01-23-2006, 02:43 AM   #9
Nan Desu Ka?!
Nan Desu Ka?!'s Avatar
Nan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to all
Send a message via AIM to Nan Desu Ka?!
Congrats on finding THE most common KADE problem EVER.
Norcal-240sx.net
Nan Desu Ka?! is offline   Reply With Quote
Old 01-23-2006, 11:17 PM   #10
91ka
s13
so no one knows the answer to my question?
Old 01-23-2006, 11:26 PM   #11
Dousan_PG
Dousan_PG's Avatar
yeah mine was same way
no biggie old news i took mine out 2+ yaers ago
people been doing it for so long not new news there buddy.
side shoudl come out too, jsut rmove the front covers and remove it. its easy.
Aaron
Pink GodziRa
Old 01-23-2006, 11:29 PM   #12
projectRDM
projectRDM's Avatar
If the tensioner wasn't 'working' you'd have chain slap and would already have jumped time. The upper guide (by the distributor) rarely breaks, only the top one.
The tensioner is oil pressurized, more pressure = more tension. Did you really have to ask that, or did you throw your brain away for a minute?
FORMERLY R240NA
Old 01-24-2006, 12:10 AM   #13
Irukandji
suprisingly my chain guide was scratchless but I removed it to prevent any future rattling. for the gasket just use the RED RTV.
Takes less than 10 minutes.
Irukandji is offline   Reply With Quote
Old 01-24-2006, 01:29 AM   #14
91ka
s13
would you mind explaining jump time?
Old 01-24-2006, 05:56 AM   #15
240shorty
240shorty's Avatar
240shorty is on a distinguished road
^^^Too much slack in chain = too much distance between chain and sprocket. Chain jump (skip) tooth on sprocket. Timing = screwed. Result = bad. Camshaft rotate later relative to crank. Engine = run poor.
Noob + good automotive book + reading = less simple questions. :-) Not to be rude, but that one is kind of self explanatory.
It's usually just the guide(s) for most people. I wasn't so lucky. Got in there to change the guides and ended up changing the entire timing setup, top and bottom, plus a pile of mush out of the oil pan. Me + dishonest seller = pwned.
240shorty is offline   Reply With Quote
