Old 01-23-2006, 12:20 PM   #1
speedfiend
Trader Rating: (68)
speedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to all
Feedback Score: 68 reviews
Send a message via AIM to speedfiend
s14 S14 Bumper Mod & Pulled Fenders
Hey guys just wanted to show off my new bumper mod. I am sure someone else has done this but just thought it turned out real nice and wanted to show it off. I also just recently pulled my rear fenders and lowered my car and I think it turned out pretty nice. Just wanted to see what you guys thought. And maybe you guys can help me figure out why my rear wheels stick out unevenly. I think it is in the rear fender itself because I have replaced the rear subframe and ruca and toe arms. Any compliments or complaints welcome. Thanx, Cameron
speedfiend is offline
Old 01-23-2006, 12:22 PM   #2
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
looks good, no paint cracks?
kouki_s14 is offline
Old 01-23-2006, 12:24 PM   #3
Dousan_PG
Dousan_PG's Avatar
s chassis are notorious for one wheel sticking out more then other..hahahhaa
i know so many people w/ the same problem. most of them track the car so could be something tweaked.
anywaas, looks good.
Aaron
Pink GodziRa
Dousan_PG is offline
Old 01-23-2006, 12:24 PM   #4
BlackS14
BlackS14 is an unknown quantity at this point
Send a message via Yahoo to BlackS14
Nice bumper mod. And about the rear tires being uneven....understanding you have replaced components, but were they both adjusted to the same degree? It looks as if (from the pictures) that you're running a couple more degress of neg camber on the drivers side rear than the passenger side....
-Bill
Once you go black you...well...you know.....lol!!!!
BlackS14 is offline
Old 01-23-2006, 12:32 PM   #5
speedfiend
Trader Rating: (68)
Thanx for the compliments guys. Everything has been aligned but I did lower it a little more and I think it may have added some negative camber to the rear but now that I look at the pics closer it does look like there is more in the drivers side. I did use a heat gun but there are still some paint cracks right at the edge of the fender but nothing up the fender. I just took some touch up paint and filled the cracks in a little. Its a daily driver so I'm kool with it not being perfect. Not looking for a show queen thats for sure. Thanx, Cameron
Old 01-23-2006, 12:36 PM   #6
kouki_s14
kouki_s14's Avatar
did you use the slugger technique?
Old 01-23-2006, 12:46 PM   #7
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
looks like it needs an aligment, need better pics.
@woooster on instagram
kuruptR is offline
Old 01-23-2006, 12:46 PM   #8
kuruptR
kuruptR's Avatar
kuruptR is offline
Old 01-23-2006, 01:03 PM   #9
A Spec Products
A Spec Products's Avatar
S14 guys are lucky
you dont get the dent like s13
looks clean, no bubble flare style pull
A SPEC PRODUCTS CORP
A Spec Products is offline
Old 01-23-2006, 02:16 PM   #10
NemeGuero
No more nissan.
NemeGuero's Avatar
I don't like the bumper mod.. It's a big gaping hole in the front of your bumper.
Car looks good though, so does the pull.
NemeGuero is offline
Old 01-23-2006, 02:18 PM   #11
speedfiend
Trader Rating: (68)
I actually used a fender puller. No baseball mods here. Thanx for the comments. Cameron
Old 01-23-2006, 03:45 PM   #12
trsilvias13
did you paint chip or crack with the puller?
nice work..
i would have cute the height of the turning signal though and match the length of the lower opening, and cut off the middle divider.
That is what im aiming for on my bumper after if fix everything and go ka-t
i like your car color.
trsilvias13 is offline
Old 01-23-2006, 03:46 PM   #13
ThatGuy
Admin Asshole
ThatGuy's Avatar
PICTURE THREAD!
It's there for a reason. Use it!
To anyone with questions, PM him.
ThatGuy is offline
