![]() Is there a difference beween the S13 and 180sx hood latch handle?
I assumed they'd be identical, especially since the S13 front end hood bolts right on. However, I put on an PS13 ARC cooling panel (on a sil-eighty) and the hood hinge doesn't clear. I temporarily tweaked the hood hinge so everything works now, but is there a difference?....If not, any ideas why it didn't clear? Should I buy a hood latch handle from a S13 or 240sx Coupe? Any ideas???? Last edited by sr_sil80; 01-24-2006 at 01:44 PM.. |
Admin Asshole
![]() Join Date: Mar 2002
The hinges are at the back of the hood and should have no effect on a cooling panel.
![]() Join Date: Oct 2004
just to nitpick, both the silvia and the 180sx in this case are S13's
high performance driveway photography ![]() zenki s14---v8 fc rx7 my crappy flickr page (drift cars whoo) |
#4 | ||
![]() I am referring to the little handle/latch that you use to open your hood, which should sit in the hole of the cooling panel. Quote:
#5 |
![]() Join Date: Dec 2002
They're the same, all S13s are S13s, whether it's PS, RPS, etc.
#6 | |
![]() Join Date: Apr 2002
S13= chassis code silvias, 180sx, and 89-94 240sx's have the same chassis. so... S13= silvias, 180sx, and 89-94 240sx's
89 S13 hatch/////98 Subaru 2.5RS |
#7 | |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
Don't act like you know car names and chassis codes when you don't. Depending on the motor on your car the chassis code differs. But I don't feel like listing them.
![]() Best way to do business with me? Make your best offer FIRST. |
#8 |
![]() Join Date: Jan 2004
Well if we went to get super technical...
RPS13-180sx,200sx, 240sx FB S13-Silvia and 240sx coupe =P But are you talking about the cable for the hood latch not clearing properly?? If so that could be because on the JDM dealys ofcourse the hood latch cable would be coming from the other side...I think I understand?
I'm from Florida so I'm probably a bit more strange than you |
#9 |
All the guy wants to know is if the hood latch is located in the same spot depending on the the front ends. Although the chassis are the same, the hoods ARE INDEED different. Now, let's ease up fellas.
I'm not hasslin any individual nor saying any individual is correct or incorrect. |
#10 | |
the hoods are definately different but I have never heard of anyone having to change or modify the hood latch when doing a silvia conversion.... your car could have been in an accident causing the latch to be bent a little, which would kinda make sense since you were able to "tweak" it and make it work.
#11 | |
s13 as class of chassis codes means all 89-94 silvia, 180sx, rwd 200sx, and 240sx s13 as a specific chassis code means 89-90 (ca18de or ca18det powered) coupe this has all been covered many times sr_sil80, you can avoid a lot of trouble if you just call it an s13 silvia, as people here tend to get kind of picky |
#12 |
I had the same belief as wootwoot, but if i'm wrong, then i'm wrong.
Basically, I have a RPS13 (180sx) w/ a Silvia PS13 front end. I got a hold of an ARC Radiator cooling panel,...the cable is fine, and the Silvia S13 hood closes w/ no problem. However, the latch handle doesn't clear the cooling panel. I had to tweak the handle to open the hood in order for it to clear. My question is,...Is there a difference between the RPS13 and the PS13 hood latch/handle assembly? If you don't know, then there's no need to respond. I will figure it out soon enough when I find a PS13 hood release assembly, but until then I though someone on here might know and could save me the trouble of finding one if i don't need to. I was trying to be as clear as possible, but I had a feeling the chassis codes will cause some confusion,...haha ...Timanator, thanks for that link...cleared up some of the confusion for me! Last edited by sr_sil80; 01-24-2006 at 11:54 PM.. |
#13 | |
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
look at your vin plate. |
#14 | |
How do go about telling people what they have/don't have w/o actually knowing. |
#15 |
Super Moderator
Trader Rating: (73)
He's talking about the VIN plate on your firewall. Also, you should tweek your hood latch to make whatever mods neccessary to operate your hood. I don't believe there is any difference.
As long as you can click your hood closed, I don't see a need for concern.
#16 |
holy SHIT i did not mean to start a derail that big.
Hope you got your hood stuff sorted out!
#17 | |
that's how dousan knows you don't have an RPS13. if you actually do have a jdm 180sx, then dousan is wrong. but i doubt it. |
#20 | |
I figured they were the same, and I figured someone on here would know more than me, which is why i asked in order to save myself the trouble of tracking down a jdm "PS13" silvia hood latch. btw, just to point it out, i read through what everyone said again for like the 10th time. and I agree w/ most of you and realize what i said may have threw a lot of people off. I didn't really get my questions answered in the detail that i would've liked as the thread got side tracked. But I noticed I never mentioned anything wrong, b/c technically I said a 180sx isn't a S13...in reality it is a RPS13 and nothing is a S13 except for the '88-'90 S13 Silvia CA18DET, everything else has its own code. I could really care less though, but I could see where you're all coming from, and thanks for all this information/confusion/criticism |
#21 | |
![]() Join Date: Oct 2003
RHD and LHD latches are different. The cable comes from the opposite side of the car, but I don't think that should affect how a cooling panel would fit.
#22 | |
all s chssis is s13 doesnt matter what motor chassis is the same the R is fstbck model the P is for SR20DET |
#23 |
Thank you dousan, i knew i wasnt wrong
