Old 07-02-2003, 10:24 PM   #1
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Post No More Spongy Brake Pedal
Wow!!!!
Ok so I had orignally posted a thread about the brake issues I was dealing with after installing a new MC. Turns out after writing a long *** post my dial up connection at work disconnected and my post was lost.
BEST LUCK EVER!!!!! Turns out that since I didn't have responses from you guys I actually went and read the instructions that came in the box and came across the exact issues I was having. I've installed a MC before but the install was a big improvement right out of the box so I didn't read on and my friend who was working on it with me didn't bother to explain how to trouble shoot problems that didn't exist.
To back up, since I bought the car my pedal has been firm, but with a long stroke before engagement, though the brake lights turn on within a few mm so I knew it wasn't the pedal free play. I changed the stock pads to KVR's which made a big difference when hot and improved fade resistance, but cold it was just as bad. I've bled the lines numorous times without a noticable change and the MC seemed like the last option besides SS lines. I had read the FSM about checking the brake booster, but the procedure requires compressed air so I ignored it.
So this weekend I changed the MC and while I felt like my braking force was improved (there was definitely some leaking past the seal), modulation was worse than ever, accompanied by a groaning noise. This wasn't going to do with a 1000 mile road trip ahead of me.
So I read the little instruction manual and right there was the procedure for curing just that series of problems.
Turns out the piston for the brake booster wasn't seating in the MC piston in the retracted position and now with the new MC the problem was worse. Pedal travel before engagement was long, even though the pedal was firm once the pistons engaged.
So an hour later, super stiff pedal with very short travel!!!!!
Here's how to do it. It should only take about an hour and really only requires a 12mm wrench, a 7mm wrench and a pair of needle nose locking pliers (non locking will work, but locking is much easier).
-Unbolt the two nuts securing the MC to the brake booster.
-Pull back the MC to reveal the BB piston
-There is a round piston with a 7mm fitting on a threaded pushrod
-The entire pusrod/ piston assembly freely rotates by itself so you will have to use the locking pliers to hold the pushrod (easier if the pushrod is deployed so have a friend press on the brake pedal or rig up a way to have the pedal depressed while you work on it, I used a jackstand and a pair of 20+mm wrenches)and the 7mm wrench to turn the piston counterclockwise (or clockwise if you have brake dragging to retract the piston). I used 1.5 full turns and it went from very spongey accompanied by a groaning noise to super firm (almost too much) while allowing the wheels to turn without dragging the brakes. My guess is if you are not getting a groaning noise with the brake pedal depressed at idle you should go less than a full turn.
Then just rebolt the MC and go for a test drive (you may want to check for brake drag by lifting a corner and spinning the wheel while it's off the ground).
Pic....
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline
Old 07-03-2003, 08:04 AM   #2
240 2NR
240 2NR's Avatar
Huh, no replies?
Well I thought this would have generated a bigger buzz.
I thought I would add that in the picture it looks like the MC is completely removed from the brake booster. If you just loosen the two nuts, there's enough flex in the hard lines that you can pull the MC away from the BB 2-3 inches, which is tight to work with, but just enough, without having to remove any lines and then bleed everything and then find out it needs to be a adjusted again (my worry before starting). I just unclipped the first two clips on the firewall and gained an extra inch or so, which was enough to work with. A shop light will help tremendously (as will not driving the car for an hour prior to trying this so the exhaust manifold just inches away is blazing hot while you work, ). Seriously, I always thaought there was more involved in adjusting this, but it was very easy and should be a lot more clear once the MC is loose and you can see the piston I'm talking about. If it still looks too hard for ya, just tighten down the two nuts on the MC and you're right back where you started.
If I knew about this 2 years ago it would have been the first thing I did on my car.
Steve
240 2NR is offline
Old 07-03-2003, 08:18 AM   #3
240 2NR
240 2NR's Avatar
OH yeah, I should have said in the topic heading, IT'S FREE!!!!
FREE Free free free freefreefreefreefree!
Steve
240 2NR is offline
Old 07-03-2003, 10:30 AM   #4
timmybgood
timmybgood is an unknown quantity at this point
perhaps this is why some people with Z32 brakes have some mush? excellent write up btw
1995 SE
timmybgood is offline
Old 07-03-2003, 10:45 AM   #5
240 2NR
240 2NR's Avatar
Could be, but my brakes are stock. I think the Z brakes has more to do with the volume of fluid being moved (more travel once engaged), this just seats the piston to begin with which eliminates the travel prior to engagement so its firm right away instead of having .5" of travel or so before actually getting some resistance. I seiously think I have less than .5" of travel total now. It rocks!
I was all set to order some stainless lines, but I guess this cures most of the issues, though I'll probably still get them.
Steve
240 2NR is offline
Old 07-03-2003, 10:47 AM   #6
Warwick5s
Warwick5s's Avatar
Warwick5s is an unknown quantity at this point
kick ***!
i'll try this tomorrow morning. my pedal seems to move about 3" before it does anything.
Warwick5s is offline
Old 07-03-2003, 11:32 AM   #7
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
Thanks!, ill have to do this when I put my 5lug and Z brakes on.
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline
Old 07-03-2003, 02:24 PM   #8
MorganS13
MorganS13 is an unknown quantity at this point
i'm gonna have to try this.. it'll be my lazy way of making up for my "dirty brake fluid" according to the dealer.
MorganS13 is offline
Old 07-03-2003, 02:29 PM   #9
Hubie
Hubie is an unknown quantity at this point
Send a message via AIM to Hubie
Thumbs up
OMG!! This is exactly what I need. Mine doesn't make a groan noise though. I'm try this tonight. If I f up somehow, then I can drive my parents car. They're out of town and I'm house sitting...hehehe. Thanks.
Hubie is offline
Old 07-06-2003, 04:13 PM   #10
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
awesome, now i dont have to buy a Z brake master cylinder. its very stiff now and ive got Z brakes!! good job man!
HighTach Motorsports
hurleyboi514 is offline
Old 08-08-2003, 11:34 AM   #11
240 2NR
240 2NR's Avatar
Had to dial back my setting by a quarter turn since I was having issues with my brakes dragging. It wasn't a huge deal and was just enough to keep my KVR's nice and warm all the time but once they got hot (during some spirted mountain driving) I could feel them noticably dragging as their friction coeffient increased. It also took a long time to cool them back down.
Took it back a quarter turn, which seems like it might have been a touch too much. Apparently this adjustment is very sensitive. The brakes no longer drag and the pedal response is better than it had previously been, however it's still a bit softer than ideal. Maybe an 1/8 turn back will be just right.
Steve
240 2NR is offline
Old 08-08-2003, 10:15 PM   #12
mrmephistopheles
mrmephistopheles's Avatar
.....and into the archives we go!!
mrmephistopheles is offline
