![]() Join Date: Dec 2008
![]() Feedback Score: 12 reviews
![]() ok so i am running a stock sidemount on my black top sr, i am going to install a aftermarket BOV.
my question is if i take the line off the stock BOV and switch it to the after market BOV is the stock one still in use? or can i jsut T off the line and run both BOV? if someone could give me some pointers that would be great. i am currently running 10LBS if that matters. |
![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() Feedback Score: 9 reviews
^what he said, no need for 2 bov's cap it off and mount your aftermarket one
TW: http://zilvia.net/f/cars-sale/390459...d9s-coils.html |
![]() Join Date: Mar 2010
i tried running a aftermarket bov on a stock setup and my car ran like crap plus it looked retarded stock side mount with aftermarket bov. why are you doing this? for looks or sound?
#5 | ||
well i installed it.. the snap ring was a BITCH! i am running the stock sidemount bov and the hks ssqv3 i installed. well the car feels like its losing boost. could someone explain why? i am probably going to cap off the stock one coudl someone explain what i need to do? i thought i could jsut take the vacume line off(run it to the new BOV) and cap the nipple coming on stock bov. PLEASE correct me if i am wrong. thanks for the help=] |
remove the stock recirc valve and plug the two open hoses or cap where the hoses attach to the intercooler. told you weird things would happen, lol.
#8 | ||
Don't run the SMIC in cali heat(I know it's winter atm, but still), with anything over 7lbs, or you are probably gonna be looking at some nice heat soak, and some nice damage to your piston. Also, don't switch to an aftermarket BoV. The SMIC gives better response with the stock one, cause its recircd. Just leave it alone until you get a FMIC.
#9 | |
![]() the side mount is ok for dd but anymore than that its safe to go with a larger intercooler |
#10 | ||
thanks for your help guys. |
#11 | |
well i dont think i need to replace the injectors with 12lbs if im correct you dont need to replace them unless you are going above 1 bar of boost.(14lbs.) if i get bigger injectors i have to get a tune. and if i get bigger injectors i might as well get a z32 MAF and get it tuned for all that but its something i dont need to really do on 12lbs. although i wouldent mind getting a safc piggyback with my stock setup (injectors and maf ect)
#14 |
i did a little bit of searching for you, it seems most people are saying 10psi on stock injectors is about the max you want to go on a stock ecu.
www.ka-t.org :: View topic - 370cc injectors 370cc injectors and T25 - SR20 Community Forum - The Dash Max boost with stock 370cc injectors? : SR20DET Forum (rear-drive) in the end its your car and your motor so its your choice and if you blow it up by running lean then so be it |
#15 | |
#17 | ||
I'm surprise your engine hasn't blown yet. Please ease up the boost. Did you even get a walbro fuel pump?
#18 |
actually this 100 octane japanese gas thing is a bit misleading. the fact is that they dont measure octane the same as we do. So in reality their 100 octane is comparable to like our 93 octane, but......i guess in CA you cant get higher than 91 can you?
#19 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
So even still, you're running lean/dangerously with it.
#20 |
Ok I have a question about this now if the op gets his fmic and the bov doesn't he still need to recirculate the system, I once read that if u don't recirculate the system that your car boggles out and sometimes die on u, since when you start spoiling your maf is reading the amount of air your getting and telling the computer the correct amount of fuel to dump into the engine, so when the system is not recirculated the computer is dumping too much fuel into the engine when it's not getting enough air, thus messing with your a/f ratio. Can someone clarify on this please, sorry not trying to thread jack but don't want to start a new thread on basically the same topic.
#21 | |
#22 |
Trader Rating: (58)
I'm almost sick to my stomach reading this post. It's 2010...there are countless turbo resources out there, and people ask questions that weren't even asked 5 years/10 years ago when no information was even vailable!
Ey yi yi. shinobis13hb, 1.leave the stock one on your car. Don't be a ricer by adding a noise maker (bov) to a stockish setup. I don't care how cool it may sound, it's not worth the aggrevation or install. 2. You have a OE side mount intcerooler, designed for commutting, marginal spirited driving. Will it work? Sure...but so will filling out your Tax forms with a Crayon. The RIGHT way is to add a FMIC before increasing power or boost. 3. Ditch that Blitz ECU In the end, when you add a BOV, do it correctly with a new flange, removing the old one, and of course recirculating it correctly. Don't cheap out. Ori
#24 |
![]() Join Date: Oct 2006
![]() ![]() Feedback Score: 23 reviews
A non-recirculated setup will not run nearly as well. You will have to raise the idle to not die at a stoplight, you WILL waste more gas, andyour car will not beas responsive.
#25 | ||
Trader Rating: (58)
Sorry dude, you're not going to convince anyone here that your car can idle at stock, and not stall. You must have a magic damn car. Quote:
Amen Brother
#26 | ||
I have a shitty cxracing BoV vented, and the only time I get any bog is when I boost, blow off valve vents, and then I come to a stop/don't up/down shift. It causes my rpms to fall to 5/600, then shoot back up to 850. Just sayin...
#27 | |
Trader Rating: (58)
Your shit is wrong Just saying My stuff is recirculated, makes twice the HP and probabyl drives like grannies buick Just saying Anytime you need to modify how you drive a car from 'stock' or normal, it's not right. just saying
#28 | ||
Slow your roll, don't get all pissy. I don't care how much HP you have, the concept of the car dying at a stoplight because your BoV isn't recircd isn't going to change just because you have a built engine(Unless maybe because of cams). JUST SAYIN
#29 | |
#30 | ||
