Old 02-14-2008, 11:38 PM   #1
2plus4plus0eq6
2plus4plus0eq6 is making his/her stupidity well-known2plus4plus0eq6 is making his/her stupidity well-known2plus4plus0eq6 is making his/her stupidity well-known2plus4plus0eq6 is making his/her stupidity well-known
ATI Super Damper VS Unorthodox Crank Pulley
Whats Better? nevermind the cost of it.
Anyone know the actual weight of both of these?
Unorthodox's website says 2 lbs I think
and ATI is 3.6 lbs total weight and 2.27 lbs for the inertia weight or something?
http://www.unorthodoxracing.com/
http://www.atiperformanceproducts.co.../damnissan.htm
Correct me if Im wrong. Thanks
2plus4plus0eq6 is offline   Reply With Quote
Old 02-14-2008, 11:41 PM   #2
S14DB
AFC #1
S14DB's Avatar
I would go with the ATI since it damps better than the factory unit. UOR is just a hunk of aluminum.
Old 02-15-2008, 06:28 AM   #3
Slidin240Wayz
Slidin240Wayz's Avatar
Haha seriously.
ATI
Slidin240Wayz is offline   Reply With Quote
Old 02-15-2008, 06:46 AM   #4
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
i thought the ATI dampner was engineered for extemely high hp applications. and i believe underdrive pulleys, when used on high high hp applications have an adverse affect? i really didn't make this up, someone back me up here!
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 02-15-2008, 06:56 AM   #5
bram StRoker
bram StRoker is an unknown quantity at this point
In theory the less rotational mass the engine has to move the more power but in this case ATI ftmfw.... no question
bram StRoker is offline   Reply With Quote
Old 02-15-2008, 07:10 AM   #6
S14DB
AFC #1
S14DB's Avatar
High RPM applications. Keeps the crank from developing nasty harmonics and movements at high rpm. High HP can make these harmonics more violent and frequent, increasing wear. These are when you will notice the most benefits but, even stock street applications will show extended life from a improved Harmonic Damper.
Underdrive pulleys when used in low rpm applications can sometimes not move the water fast enough or keep the battery charged. It helps in High Rpm applications to reduce drag, keep the water pump from cavitation and reduce bearing and stator wear in the alternator. On the SR this can be accomplished with a underdrive water pump pulley.
Best solution is a ATI super damper and a underdrive water pump pulley. For street an ATI and a Greddy pulley kit.
And for the ballers:
Old 02-15-2008, 08:33 AM   #7
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
more like 5.7
ps, i have two unorthodox crank pulley if anyone interested
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 02-15-2008, 06:24 PM   #8
2plus4plus0eq6
so ATI is like almost 3 times the weight of the unorthodox one?
Isn't lighter better though?
Old 02-15-2008, 06:30 PM   #9
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
I've been wondering about these... My friend say there bad for DD cars... I understand why now.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 02-15-2008, 06:36 PM   #10
burnsauto
burnsauto's Avatar
in some cases yes. but did you read the rest of the thread???
the fluid dampener helps keep crank vibrations to a minimum at higher rpms. even the most precisely balanced crank..will have vibrations at high rpms. the fluid dampener can help prolong the life of your engine, helping control vibrations and lessening bearing damage. granted you wont get the 5 extra hp as if you used an aluminum pulley, but personally, i'd much rather have that piece of mind-rather than an extra few ponies that i could get elsewhere.
when the time comes that i want to replace the stock pulley, i wont even look at anything else besides a fluid dampener....but thats just me, i care about my engine.
Old 02-15-2008, 06:58 PM   #11
S14DB
AFC #1
S14DB's Avatar
When did I say they were bad? All I said is that you see less of a benefit on a DD.
Old 02-15-2008, 06:58 PM   #12
2plus4plus0eq6
ahh that makes sense. thanks
Old 02-15-2008, 07:06 PM   #13
MrChow
MrChow's Avatar
Did I say you said that they were bad?? =o
No a friend IRL.
Old 02-15-2008, 10:24 PM   #14
burnsauto
burnsauto's Avatar
S14DB, who manufactures those pulley's?
VERY trick pieces
EDIT: - nevermind. should've realized to look at the images origin address. naprec has some very nice parts there..
