Old 12-17-2008, 08:15 PM   #1
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
so....wideband...
well i finally got my Uego widband gauge...
and heres my question on this...do i keep my stock o2 sensor and just wel the secondary bung to pipe...
im still on stock ecu but am going Nistune by the end of the year...so i need some imput...
i figure that i do need ot keep my original o2 sensor because its connected to my ecu...
or is there a way to connect the wideband to my stock ecu harness and get rid of the stock o2 and install only my wideband...
any help is greatly appreciated
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 12-17-2008, 08:41 PM   #2
tgd89
tgd89 is on a distinguished road
The wideband sensor needs to be at least 18 inches from turbo/headers, that's what most manufacturers recommend.
So I would recommend welding a second bung and keeping the stock sensor for now as the voltage outputs of a narrow band sensor and wideband sensor are not the same.
tgd89 is offline   Reply With Quote
Old 12-17-2008, 10:16 PM   #3
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
i was thinking something along those lines
i was also wondering whats the best metal to weld the bung provided by the Uego to the elbow
PSN
Old 12-17-2008, 10:35 PM   #4
ChicagoS14
ChicagoS14's Avatar
ChicagoS14 is making a name for him/her selfChicagoS14 is making a name for him/her self
Send a message via AIM to ChicagoS14
If its any help, I run a test pipe on my S14 so I had the AEM bung welded by a muffler shop to my test pipe. so far its doing good. I also have a turbo on my KA and in the AEM manual from what I remember recommended 36 inches away from the hot side of the turbo. You dont want to too far, but too close will also mean that the 02 sensor will burn out quicker, also the incredible temps of the exhaust might cause some harm as well, so I wouldnt have it welded too close to the turbo on the downpipe either.
95 240SX 1JZGTE | SC300 2JZGE daily
www.240sxguide.com
ChicagoS14 is offline   Reply With Quote
Old 12-17-2008, 10:49 PM   #5
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
so 36'' fromt he hotside aye
and from what i remember it has to be on a top side correct..
so i looked at the wires black is ground red is power....
blue and white???
also whhere is is safe to run power from properly
PSN
Old 12-17-2008, 11:14 PM   #6
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
You can just weld another bung at a muffler shop on the downpipe or testpipe. Just make sure the sensor is not pointing completely down or up.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 12-17-2008, 11:18 PM   #7
slw240sx
slw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant future
Send a message via AIM to slw240sx
I run one about 6-8" from the turbo outlet, with a heat sink on it made from aluminum sheet metal.
i have another in the bottom of the down pipe right after it curves under the car.
the first location is accurate all the time, the one further down stream is slightly off at idle, but once you start pushing some exhaust gases it ends up reading the same as the first location.
i am running a AEM in first position and a innovate LC1 in secondary.
yes i know its dumb, but i bought a LC1 to use as a wideband for my megasquirt to run off of. then we started getting such good deals on AEM's that i wanted a gauge, but for the cost of the innovate unit i just bought the AEM. I didnt feel like removing the LC1 and pulling the dash apart to get to it.
http://www.forcedfabllc.com/
slw240sx is offline   Reply With Quote
Old 12-17-2008, 11:20 PM   #8
tgd89
The red wire should be wired to a switched 12v, and the black is ground. Now the white wire is the analog 0-5v output, and the blue wire is the serial(digital) output.
Old 12-17-2008, 11:26 PM   #9
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
yeah see im looking at my stock o2 and its location is on th estock elbow...i was thinkin buyin an aftermarket bung and having it welded a bit lower from the other bung for the stock o2 hole
PSN
Old 12-17-2008, 11:30 PM   #10
slw240sx
I have ran mine there for a few months. its been fine. you can also get a O2 extender bung from innovate which allows you to run it closer. or i have even seen guys buy spark plug nonfoulers from autozone and drill it out and use it to space out O2s, but thats mostly for OBD2 tricks. you can probably get a shop to weld one in for you for under 40$. i know i have done a ton of them, i normally charge 35 for downpipes that are off. it only takes like 5mins to drill the hole out and weld it up.
Old 12-17-2008, 11:44 PM   #11
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
well the one problem that i ran into is the stock elbow is cast IIRC
while the bung i think is alumn
so thats why i was thinking of just buying a new elbow have the bung welded on that
this would solve 2 issues
finish my aftermarket exhaust
get wideband on to properly adjust fuel
but this whole it to close ot the heat is worring me...and i still need help getting power to it...
PSN
Old 12-18-2008, 12:28 AM   #12
usdm180sx
usdm180sx's Avatar
Steve, be sure to hook up the wideband after you get the car tuned. Running rich kills 02 sensors!
-Norm!
Old 12-18-2008, 12:30 AM   #13
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
well i just want to set the fuel pressur to the right amount via FPR and gauge
and use the Uego to make sure i dont lean out
should be safe
and i dont mind replacing the sensor slong as it reads fo rnow
PSN
