Overheating.
Setup:
Koyo Rad FAL pushers. Issue: I had the fans running off a thermistor, to a fuse, to a relay(40amp). The relay supplied power to the fans. I kept burning the relay up and the fans would not get power. So I added another relay, and put each fan motor on a separate relay. Today it burned either the relays up, or the motor fans. I can't seem to keep the car from overheating at all with this setup, and I didn't have room for the pullers unless I switch to a different brand. Also considering getting a vented hood. The radiator cap vents when the car is about 195-200 degrees. Just seeing if anyone has any other suggestions to fix the issue without having to switch my fans out. |
![]() Join Date: Oct 2006
If you're overheating just daily driving, especially when you're not stuck in traffic, the radiator or fans arent your issue. You probably have air in the system.
Agreed. Get a coolant bleed kit. There is also a write up on changing a radiator and tells how to get the air out. Running it while parked on an uphill slope or jacked up in the front will allow the air to escape. Take off the rad cap and run it with the heat on high and this will allow the bubbles to work their way out.
#5 | |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
![]() ![]() PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r ![]() |
![]() Join Date: May 2006
It's certainly possible that you have air in your system - I just jack up the front of the car, turn the heater on, and open the rad cap and bleeder bolt until solid water comes out (top off the radiator also).
Tell me about your electrical setup - for OEM-style you should have a fused +12V source going to the '87' pin and the '85' pin, the fan's power lead coming to the '30' pin, and a ground wire connected to the '86' pin and your thermistor or a switch (the switch or thermistor will provide ground for the relay). For two fans, use two relays, each fused separately if you want, connected to the same switched ground. If you're using 40A relays, you will not burn them up.
Yes, that is my setup. I can get a wire specific diagram if needed...but I'm almost 100% sure it's wired like that. The thermistor supplies ground...fuse before relays(they share the same ignition wire, have two separate constant power wires) and run each motor individually.
#10 | |
Harbor Freight, I believe, has these - but I can't find them on the web site for some reason.
I know Sears also has them, but they'll be more money.
They are right^^^ you probally have air in your system.
I dont really have anything to add i would say they pretty much coverd it. Oh i would take your thermostat out. Bitch is worthless, my car was allways overheating ripped the thermo out and ran fine. |
#14 | |
If you're having problems getting the coolant system bled properly, and think it's the thermostat, you can put it in a pan of boiling water and see if it opens, and/or just replace it. If its good, and you're still having problems with overheating, it's because you've got air behind the thermostat - keep bleeding the system as described above!
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
#17 |
I have good wiring ran to all the relays, and I believe they are 12 gauge.
By they share an ignition, I mean that both relays receive ignition power, but also have a constant 12v. (4 plug....12v, ignition, ground, output power to fans). I'll try getting the car on stands and see if i can get it to puke all the air out itself...I just don't see why the fans would over load the relays from running too long. |
#18 |
Trust me, it's not the fans. The fan only serves a purpose when the car isn't moving. A moving car moves air through the radiator faster than any fan can. Bleed the system.
#19 |
![]() Join Date: Jun 2004
Are you switching hot, or on the ground?
Switch on the ground, switch on the ground.
[email protected] |
#20 |
^^^ John Griff in da houssssssssssssssssse!!!!
I think he said his wiring was as I described - if that's the case, he's good ![]() Still sounds like air in the system. Does it overheat around town, or on the freeway?
#21 |
It's a coolant funnel, you use to various fittings so it goes on top of your radiator like a radiator cap, put the big funnel on, pour coolant until it's half full, start car, idle and turn heat to full blast, let it warm up, watch the bubbles till they're gone. voila! fully bled. I bought mine off a tool truck that comes by my work. edit: lol looks you got it. |
#22 |
Yes, I'm switching off the ground. I'll try jacking the front of the car up and bleeding it as so as soon as I get the wheels back on it.
Do you really think that would cause the relays to burn up though(car not cooling, fans running too long?) The car ran fine for about 2 weeks with this setup since I changed it to 2 relays, and it just stopped the other day when I posted this. Last edited by Deftec; 04-27-2009 at 06:43 PM.. |
#23 |
Update, took the car out, ran fine for a while, got it home and parked it, antifreeze starts blowing everywhere. The relays burned up again. I made 100% sure all air/etc was out of it. So the only option I can really do now is to take the thermostat out and see what it'll do.
#24 | ||
#25 | |
I did bleed it with it elevated and the heater on. Crimps and all connections/etc are good...but how could I regulate the current being drawn from them? They run fine, but if the fans run for too long it burns the relays up. I also am led to believe I need a higher PSI radiator cap, I put a new one on, and when the car gets warm, half throttle it vents slightly, so I'm going to try and up it to a 15psi. |
#26 | |
You can't regulate the current going through each relay using the relays, you have to change how the load is applied - if you're sure that the wires are going to the correct pins on the relay (which I'm not), you need to use relays rated for the huge current you're pulling.
#28 | |
