#993 |
![]() Join Date: Sep 2004
Thanks a lot, I appreciate it. I feel the same way about Forrest Wangs S14... looks like a boring black car on vskf's in pictures. then you see it in person and it's even quiet while drifting.
#995 |
I think Flybert had some similar problems with his car, turned out to be a bad maf... that fixed it for a bit. he got a power fc d-jethro and eliminated the maf and car runs great now.
I've pretty much narrowed it down to an engine management system to fine tune everything to the bone and just switch to map. I hate dealing with maf, but the cost of converting doesn't even seem to be worth it. I just want to drive my car... |
#998 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
Again, it's a crude way to 'fix' an issue. Quote:
If you just want to drive your car, and aren't going for the biggest HP, just throw a rom ecu on the car and enjoy it. I'd hate to spend all that cash on a EMS with a map to fix such an easy issue ya know, as it's still not guaranteed to fix the issue. Super Easy. Just get a plug from any old Nissan and wire it direct. I like keeping the port on the passenger side as well, as it eliminates cables all across the steering wheel and my legs. It's a great tool.
#999 | |
and or just directly wire it to the ecu harness its 5 wires only
built ka-t |
#1000 |
I have the plug. I just don't have the wires in place on my f3 plug for the consult. I know which pins it is, I just snipped the wires and tied them to the side. There is a post on here somewhere to show how to wire it back up.
But I eventually plan on getting a twin scroll setup for my engine hence why I would buy a standalone engine management system. I have a few knock sensors but even on my KA both still threw 34. It's normally some gay wiring issue. My maf wiring is fine, because I can put a bad maf on their or keep it unplugged and it runs limp and makes my spark plugs black, backfires and all that madness. this was with a boost leak before I changed the turbo housing, same wiring setup. before I did the knock sensor trick. |
#1001 |
So I flipped the ECU today to do the proper code procedure. I believe I left the ecu in the position to read codes, 55 when I flipped it around automatically when I put it on the on position.
So I did the red bulb mode 1 engine off testing, bulb works. pass. I did the mode 1 engine one test, engine warm 2000rpm, no light. pass (if the light comes on it means bad ecu or cam angle sensor error.) I did the mode 2 engine off test after running the engine, engine off key set to on, 5 slow blings, 5 fast blinks. pass I did the mode 2 engine on test, 5 slow blinks at running temp solid 2000rpm rev. pass (this is to make sure the 02 sensor is working.) So I'll let you know if it runs any different now that it's back to it's proper position all the way counter clockwise. |
#1002 |
My car officially hates me...
drove to LA today went to girlfriends moms, around the corner from the police academy... some cops roll by my car, check it out then do burn outs onto the on ramp lol. I'm driving home in bumper to bumper traffic after stopping in old town pasadena to pick up new years tickets to menage. I hear a pop and my battery and brake light come on, I immediately pull off of the freeway in front of someones house, pop my hood and somehow the alternator belt came off, and in the process grabbed my TPS sensor and snapped it off of the throttle body. Wires are a little fucked, but both studs that hold it in place are now broken inside of the throttle body. I am sitting here trying to figure out how in the fuck i'm going to get this belt back on the alternator, turns out the nut that holds the pulley in place came loose. So it's been vibrating back and forth and gave the belt enough slack to come loose. So I took the nut off and the pully, wrapped the belt around it and pulled it back over it's stud, screwed on the nut and secured it temporarily with the gum I was chewing. The throttle position sensor I grabbed two zip ties and tied it down in place for the time being. It got me home, no problems. FML. |
#1003 |
Trader Rating: (58)
Ah man that's a killer! Of all things to bust off too, the freakin TPS
![]() Did the car run any better? Who did the harness for you, yourself?
#1004 |
I did the harness myself...
car didn't really run any differently under load. I think what pisses me off the most is after I had to zip tie the tps back onto the throttle body for the time being low end response is like twice as good as it was before, but still breaks up past 4000 rpms lol. |
#1006 |
the belt didn't snap or get damaged, the alternator just let it come loose. Luisgonz said that it felt loose and it has been squealing as of a few weeks ago. I should've tightened it.
#1008 | |
![]() Join Date: Feb 2006
For real. The car is just working its problems out. Dont be too discouraged. You'll get everything worked out I'm sure. Wish I could give you the answer but looks like you've been over everything I can think of or someone has mentioned it. But the fact that the ECU is giving you 55 makes me suspect a MAF. ECU won't see a bad MAF, and the idle test/limp mode test is not 100% fool proof. OR there is a leak that opens up at boost. Can you drive smoothly past 4 grand without boosting or does it break up either way? A) If it's under boost I had an issue with my spark blowing out due to gap (I was at 22 psi). B) Or it could be a bad coil pack, they break up intermittently when going bad especially higher rpm under boost. Check them for cracks. C) Also check your timing. Restab the CAS per FSM, even go as far as checking the dimples on the chain. Last edited by OBEEWON; 12-30-2009 at 12:25 PM.. |
#1010 | |
Trader Rating: (58)
If you did the wiring, I'd just recheck what I've done at that point and go from there. I (myself) dont' trust myself with the wiring stuff...to me it's cheaper to just pay 100 bucks to get it done...man oh man I'd be wanting to shoot people over wire issues. As I tell my buddies...I'll stick with engine building
![]() Quote:
However the stumper, is that hte car will rev and pull to redline, so long as he doesn't go WOT immediatly...but can at redline...it's very odd. Did you watch the video? It's not a hardware issue if you ask me...electronical for sure (including maf/sensors). I'm just confused as to why it's depending on part throttle...maybe it's reverting to some sort of wacky pull timing map, but it shouldn't restrict the RPM's from revving...which is why I initially thought it was failsafe mode of some sort, or the stupid ecu holding out...it's just odd odd odd.
#1011 |
Yeah Ace, something you just said reminded me of how I fixed a similar prob.
I doubt you have the wiring wrong Wayne. MAF wiring is pretty hard to mess up (like 3 wires) and if it was the car would be running alot worse. Check you intake for leaks. Any VAC leaks will make for a discrepency in the MAF reading and cause rich popping or whatev. If you have a custom intake make sure your MAF is far enough from your turbo. IIRC MAF needs to be at least 10-12 inches from the turbo or it will cause turbulence inside the MAF. I had all those things wrong and I fixed them after swapping MAFS and doing timing and it fixed my issue. |
#1012 | |
I had a hairline crack on my hotpipe that opened up to about 1/8 inch under pressure. Couplers and aluminum charge pipes especially like to open up when boost is climbing. Usually found on the higher pressure side of the intercooler before the pressure drop. |
#1013 |
to answer the question, I am panamanian, jamaican, and irish. And this is why I suspected it's a boost leak all along. it revs just fine, as long as I don't goose it it goes all the way up just fine...
the slightest change in boost pressure needed to get up, it wont hold it. but start at the highest, the leak would be irrelevant as 9 other pounds of boost is still getting through where 1 pound may be leaking somewhere. |
#1016 |
![]() Join Date: May 2006
No WAY!!! I'm Panamanian, Jamaican, and...
... eh who'm I kidding, no I'm not. Where's the love, ya'll.
#1017 | |
Trader Rating: (58)
#1019 | |
Trader Rating: (58)
thrift store intake ![]()
#1020 |
Oh don't worry man, if it were up to me financially id have a tomei crate engine in it and some crazy ass turbo set up. But baby steps, I'm sort of glad that I'm having these problems because I learn more about the set up and can help other people with their problems.
