Old 09-04-2012, 04:00 PM   #1591
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
When you slap over fenders on, you're supposed to cut the oem fender high up, both inner and outer since theres two metal. Then you're supposed to reweld them back together so the its sealed. Doesnt look like they cut the old fenders high enough.
From the looks of the picture, it doesnt look like they welded/sealed the inner and outer fender back together. You'll get shit/waster getting inside your car.
Here's a good step by step of the process...
http://www.cardomain.com/ride/392168...-silvia/page-4
CLICK HERE!!!
Old 09-04-2012, 04:11 PM   #1592
dazed
Trader Rating: (37)
dazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the rough
Feedback Score: 37 reviews
Yeah, that's what I was thinking.. It looks like they didn't cut the old ones high enough.
I watched them doing some welding so I think they did that part. Just kind bummed now. My own fault I guess for not inspecting it better.
Edit: Went down to the bodyshop (this is a couple months later after the work has been done). Told them the deal, showed them pictures of what it's supposed to look like. And acknowledged they fucked up and are going to cut the original fender up higher.... which they should have done in the first place... but at least I don't have to threaten legal action. Going to watch them do the whole thing this time possibly.
So my question is solved. Anyone pics of what an over-fender install is NOT supposed to look like? Check the bottom of the last page.
dazed is offline   Reply With Quote
Old 09-05-2012, 01:10 AM   #1593
Silvi
Silvi is an unknown quantity at this point
What about stretching 225/40 on 18X10J?
Is it safe? btw i'm talking about the rear wheels(+drifting sometimes)
Silvi is offline   Reply With Quote
Old 09-05-2012, 08:58 AM   #1594
fliprayzin240sx
Not that big of a deal...thats what i run on my fronts. Seen people stretch 215s on 10js.
CLICK HERE!!!
Old 09-05-2012, 05:18 PM   #1595
blockedwizard
blockedwizard's Avatar
blockedwizard is an unknown quantity at this point
Hey there
I have 18x8.5 +25 lmgt4's with 235/45/18's mounted for the front
And 18x9 +30 XSA 02c's for the rear, still no tires
This is for my s13 coupe, with lowering springs on stock shocks and hammered front fenders, probably gonna roll both fenders, and eventually get coilovers. But for now on lowering springs.
My questions are what tires should i run in the rear? maybe throw the 235/45's from the lmgt4's to the works, and get something like 215's or 225's for the lmgt4's? Or go with a whole new set or different tires?
Also will i need spacers? im guessing i do
Thanks
blockedwizard is offline   Reply With Quote
Old 09-05-2012, 10:01 PM   #1596
fliprayzin240sx
You dont need spacers to fit them but you'd probably want some spacers to get them somewhat flush to the fenders. You shouldnt have to roll/pull the fenders on this setup.
As far as the tires, you probably wanna get rid of the 235/45-18 all together since those are too big for these cars. I doubt you'd fit those tires up front without hitting the top of the struts. I'd run some 215/40 up front and 225/40 in the rears.
CLICK HERE!!!
Old 09-06-2012, 01:21 AM   #1597
Mustache240
Mustache240's Avatar
Mustache240 is making a name for him/her selfMustache240 is making a name for him/her selfMustache240 is making a name for him/her self
what size spacers should i run on 17x7.5 +35 with 20mm overs on the rear (car came with them) the tire size im running is 235 45 17. I want the wheel to sit sorta flush with the fender, since im planning on tucking.... car has coils on it
Mustache240 is offline   Reply With Quote
Old 09-06-2012, 04:47 AM   #1598
Silvi
Thanks!
As i know the stretch of 225 on 10J is pretty serious..
So if i drifting sometimes with stretch like this, any chances the the the tire will rip at the stretch points under pressure? or its fully safe?
Old 09-06-2012, 09:33 AM   #1599
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
You have 20mm overs...and you want to fit skinny 7.5"...you're going to need a monster spacer to get this to be flush.
Honestly, if you can trade up to something a little wider and has a better offset for the S-Chassis, go with that.
Unless you're dumb enough to go with these for your shitty sized wheels:
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 09-06-2012, 02:12 PM   #1600
fliprayzin240sx
Originally Posted by Silvi View Post
Thanks!
Like I've said before, the same exact wheels I have up front (Work Equip 18x10 running 225/40-18s) are my track/daily wheels up front since I've run nothing but Dunlop Star Specs. I've been running 10js on 225/40s since 2007. Never had an issue. I've even had a small leak that caused one of the wheels to get down to 15 psi and didnt even break the bead.
CLICK HERE!!!
Old 09-06-2012, 02:12 PM   #1601
fliprayzin240sx
You gotta be either a fucking retard or trolling...
CLICK HERE!!!
Old 09-06-2012, 02:53 PM   #1602
Sean P.
Sean P. will become famous soon enoughSean P. will become famous soon enoughSean P. will become famous soon enoughSean P. will become famous soon enough
Going 17x9+12 up front and x9.5+12 in the rear
Should I go 215/40 f and 215/45 r or 215/45 f 225/45 r?
Would a 215/45 up front cause rubbing issues?
Sean P. is offline   Reply With Quote
Old 09-06-2012, 02:53 PM   #1603
CRPS13
CRPS13 is an unknown quantity at this point
Wow, you guys are actually answering some of these guys' questions. Wtf is going on in here.
CRPS13 is offline   Reply With Quote
Old 09-06-2012, 02:55 PM   #1604
CRPS13
I would run a smaller profile in the front. I have 215/45's up front on mine and it's keepin me from going any lower without drastick modification.
Old 09-06-2012, 03:01 PM   #1605
zooopreme
Trader Rating: (38)
http://i.imgur.com/Nkpnm.jpg
Depending on how low you want your car, 45 will be fine. At the height you're at (with 45), it will require SLIGHT hammering of the inners depending on how horrible your coilovers dampers are.
And for the rear, that will be fine. 215 225 doesn't matter in terms of fitment.
If a question doesn't get answered, I get PM's from people. So I might as well address it where people can see.
Old 09-06-2012, 03:02 PM   #1606
Sean P.
Thanks for the responses guys, so would you suggest just getting the 215/40 in the front?
Old 09-06-2012, 03:06 PM   #1607
zooopreme
Trader Rating: (38)
Yep.
msglngth
Old 09-06-2012, 05:42 PM   #1608
fliprayzin240sx
Not really, cuz I'm ignoring that one. The whole idea of running spacers on skinny ass wheels with shitty offset, that I dont even think would look good on an Accord, and get it flush on a 20mm spacers is the dumbest shit I've seen in a while.
Well take that back, this and the guy in tech asking why his wheels look off when he's running 2 different offset wheels up front, is probably neck to neck right now.
CLICK HERE!!!
Old 09-06-2012, 06:06 PM   #1609
AndyG
AndyG's Avatar
AndyG is an unknown quantity at this point
I got some rims and tires for free and i was wondering what size tires i should get to stop the tires rubbing but still get the meaty look. They are high negative offset 15x8 mangels rims with P235/60R15s. obviously they are too big and they rub the firewall really bad at full lock. any help and advice would be appreciated!
here are some pictures:
-Andy
AndyG is offline   Reply With Quote
Old 09-06-2012, 07:33 PM   #1610
zooopreme
Trader Rating: (38)
They do what? Rub the firewall at full lock?! What does your front suspension look like?
Just kidding. 225/50 or 55. Take your pick.
Old 09-06-2012, 07:55 PM   #1611
JDM SPUG
JDM SPUG is an unknown quantity at this point
Does any1 have a varstoen 2.2.1 18X10.5 with the rear 300zx calipers?
I want to know if there would be a clearance issue because the people at varrstoen don't know.
Thanks
1998 240sx 2jz swap in progress
2006 FULLY built WRX Rotated w/ PPG's
JDM SPUG is offline   Reply With Quote
Old 09-06-2012, 08:00 PM   #1612
fliprayzin240sx
Thanks
They clear the fronts, the rears will be nothing.
CLICK HERE!!!
Old 09-06-2012, 08:01 PM   #1613
zooopreme
Trader Rating: (38)
^I'm not even going to answer that. That's such a dumb question. When has anybody ever have any clearance issues with a rear caliper that doesn't sit out further than where the rotor meets the hub?
Not even flat spoke designs like some mesh wheels will touch that caliper lol.
Old 09-06-2012, 08:04 PM   #1614
JDM SPUG
you didnt have to answer it some1 already did and when you call and dealer for varrstoen they say at least +22.
Old 09-06-2012, 08:05 PM   #1615
JDM SPUG
Thank You.
Old 09-06-2012, 08:06 PM   #1616
zooopreme
Trader Rating: (38)
For what it's worth, google could have answered your question if you were resourceful enough, you little baby.
Again, this thread requires understanding and research on how wheel fitment/offset work. Not to be spoon fed information.
Old 09-06-2012, 08:08 PM   #1617
fliprayzin240sx
Offset has absolutely nothing to do with brake clearance. You can have -35 rims and still not clear the brakes.
CLICK HERE!!!
Old 09-06-2012, 08:29 PM   #1618
AndyG
AndyG's Avatar
Thanks you!
-Andy
Old 09-06-2012, 10:01 PM   #1619
blockedwizard
Thanks alot man, i figured id need spacers to make 'em sit flush. And the tire options makes it cheaper and easier to find em, thanks again
Old 09-06-2012, 10:03 PM   #1620
ghoti
ghoti's Avatar
ghoti is an unknown quantity at this point
Caliper overhang?
Originally Posted by SaNTi View Post
^ That shit always scares me... and I clinch my asshole a little bit.
ghoti is offline   Reply With Quote
