Old 09-26-2013, 11:51 AM   #151
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
I'm pretty well aware that "Matej" and "performance" are words that do not belong in the same sentence together. Well, unless the word "poor" or similar is attached to the word "performance".
racepar1 is offline
Old 09-26-2013, 11:52 AM   #152
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Which type of skidplate is best for performance?
http://bhworld.wordpress.com/
Brian is offline
Old 09-26-2013, 11:53 AM   #153
Brian
Brian's Avatar
Trader Rating: (54)
Matej - I think if you rub a bunch of rainX on your skid plate, you will have no problems. The water will just glide by it and won't even have a chance to "stick" to it.
Problem solved.
Brian is offline
Old 09-26-2013, 11:54 AM   #154
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Problem solved.
Would relocating the rear window wiper to the skid plate work?
Matej is offline
Old 09-26-2013, 11:56 AM   #155
racepar1
racepar1's Avatar
Manhole cover...
racepar1 is offline
Old 09-26-2013, 12:02 PM   #156
Motary
Motary's Avatar
Motary is making a name for him/her selfMotary is making a name for him/her self
Send a message via MSN to Motary
Originally Posted by racepar1 View Post
Race cars have swaybars dude. There is NO performance advantage to taking out at least the front swaybar. Although I used to run without a rear swaybar. As a matter of fact you want a stiffer front swaybar.
Stiffening up the front increases understeer and roll bars increase lateral weight transfer so they are not all that great
Motary is offline
Old 09-26-2013, 12:03 PM   #157
Matej
Trader Rating: (39)
You are the one whose oil pan is above the cross member. Do you even care about center of gravity?
Matej is offline
Old 09-26-2013, 12:05 PM   #158
OBEEWON
OBEEWON's Avatar
Originally Posted by aga View Post
i was thinking of installing some bookshelves by the rear passenger seats...for long journeys, you know.
Hahahahaha
isnt this about hydroplaning?
Problem solved.
This whole thread made me spend more than 10 min on Zilvia today.
Matej
Mike
Brian
Racecarpar1234
Thanks guys.
Also this one time I made my splitter out of some stuff I found in the woods. It was some type of plastic that smelled like lady crotch. Didn't matter because it broke off the first trip I took.
I should have used wood, but it was 2003 and I was more worried about lady parts.
OBEEWON is offline
Old 09-26-2013, 12:10 PM   #159
Brian
Brian's Avatar
Trader Rating: (54)
The only problem with making the splitter panel so perfect at cutting through the air is that it almost becomes too slippery and you actually LOSE downforce. The air can't even "grab" onto the panel to create the downforce effect.
When you are out on the track and every tenth of a second (and sometimes smaller measurements) matters, this becomes quite the important thing to consider.
So, even though some of you guys think you are a great garage mechanic, I'd think about leaving this one to the real engineers.
Brian is offline
Old 09-26-2013, 12:12 PM   #160
OBEEWON
OBEEWON's Avatar
When winning matters.
OBEEWON is offline
Old 09-26-2013, 12:25 PM   #161
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
this thread.... lol. oh zilvia and its zilvians. in for more info and shenanigans
edit: I win obeewon
http://www.motoiq.com/MagazineArticl...ilvia-S13.aspx
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline
Old 09-26-2013, 12:35 PM   #162
racepar1
racepar1's Avatar
That COMPLETELY depends on the car. There are multiple reasons for understeer and oversteer and multiple solutions. 240's don't have much issue with understeer. The PRIMARY concern is limiting on-throttle oversteer. Thanks, but I understand pretty well how swaybars work.
Yes, the higher the better. I was planning on mounting my engine ABOVE the hood for maximum oil pan protection.
racepar1 is offline
Old 09-26-2013, 12:37 PM   #163
OBEEWON
OBEEWON's Avatar
Originally Posted by hellion240sx View Post
Dang.
Checkmate. The better sir won.
I use my oil pan to protect my engine from hitting the earth.
OBEEWON is offline
Old 09-26-2013, 04:14 PM   #164
InsTanCeZ
InsTanCeZ's Avatar
InsTanCeZ is an unknown quantity at this point
What if you made an oil pan out of wood? Would that work?
ACE マジック HEART
InsTanCeZ is offline
Old 09-26-2013, 04:15 PM   #165
ayuaddict
ayuaddict's Avatar
The sway bars from my vehicle have been discarded for race car purposes.
I feel that leaving the front sway bar on is beneficial for protection, was the issue binding or lower strut clearance?
ayuaddict is offline
Old 09-26-2013, 04:30 PM   #166
lflkajfj12123
My sway bar was pretty much ground down flat. When I would hit things the whole front end would jump and you'd feel it in your tailbone. I removed it because I have stiff springs which basically takes over most of the sway bars job. Now my underbody has more clearance and the car feels like a Lexus with my superior Bride seating. I can now hit 130 on the wangan without fear of breaking my back on a bump. Any under panel would reduce my ground clearance. Raising the car is simply not an option because it would raise my race car's center of gravity, which would make me an idiot.
lflkajfj12123 is offline
Old 09-26-2013, 04:48 PM   #167
Matej
Trader Rating: (39)
The sway bar end links kept breaking or ripping out of the LCA's.
One time I discovered that the end links were ripped out on both sides and I did not even know how long I had been driving with the sway bar disconnected, so I guess it did not make much of a difference to me.
It did work well for protecting the pan though, but then I raised the engine anyway.
Every aftermarket oil pan should have a skid plate. With a NASA-spec layer of rubberized synthetic material underneath, for excessive cushioning capabilities.
And plywood.
Matej is offline
Old 09-26-2013, 05:04 PM   #168
InsTanCeZ
InsTanCeZ's Avatar
Hey s0ap, what's your spring rates? What kind of coilovers? Do you guys remove rear sway bars too?
ACE マジック HEART
Old 09-26-2013, 05:11 PM   #169
xoxide
xoxide's Avatar
xoxide is an unknown quantity at this point
I hate to admit this, but this was actually a local jax person.
xoxide is offline
Old 09-26-2013, 05:57 PM   #170
Frank_Jaeger
What about pegboard splitters? I've got one in my garage I'm gonna be throwing out.
Frank_Jaeger is offline
Old 09-26-2013, 07:27 PM   #171
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
That's Jabroc not plywood.
...and nobody else caught this.
https://www.pegasusautoracing.com/pr...p?Product=6180
Jabroc is what the pros actually use and it's actually not cheap at all. They are not buying sheets of plywood from god damn Home Depot.
With that said. Whatever. If it keeps the stanced-kids happy they who cares.
Corbic is offline
Old 09-26-2013, 07:33 PM   #172
Corbic
Corbic's Avatar
Not sure how that would help. Stock pans crush under their own weight. I'd envision the pan ripping off, tearing or being pancaked still.
Building some off-road style rock protection might work better.
Corbic is offline
Old 09-26-2013, 07:35 PM   #173
NoPistons!
NoPistons!'s Avatar
NoPistons! is an unknown quantity at this point
The best protection would probably be one or two round metal tubes connecting the radiator support and crossmember, going under the oil pan.
I'll be the one almost 30 year old in here that isn't going to act like a fucking snob child and say this.
1. H brace. Tie the tension rod brackets together and then link those to where your lca's fit to the crossmember. Profit. Dude friend of mine had one on his integra he dumped and i told him that shit was a waste of money until we rode around in it a ton. His oil pan was saved on many occausions. H brace has taken one hell of a beating.
2. I could see having a plywood splitter on a kitted/vented hood car that drifts being super beneficial for cooling.
3. Telling people to build a car how you want it built is fucking lame.
Just another broke ass drifter
NoPistons! is offline
Old 09-26-2013, 07:45 PM   #174
Corbic
Corbic's Avatar
I still don't understand what exactly you guys are protecting your oil pans from. More than that I am wondering if there is something wrong with all the 240's I have ever owned/worked on. On all the 240's that I have seen the oil pan is ABOVE the crossmember and behind the swaybar. IMO that seems like pretty damned solid protection right there.
Give up man.
No one putting a plywood "skidplate" on their car cares.
The point is they stick out an inch from the bumper and deflect cones at drift days and help the car skid over curbs, dirt and rocks when you go off the track. We're not talking about pros or even well pre-paired tracks. Shit happens.
We can debater to no end it's actual effectiveness, but if people think it works, well trusting your weapon is half the battle.
Let them have fun and in 5 years maybe they will go "god that was dumb".
Corbic is offline
Old 09-26-2013, 07:47 PM   #175
KoukiGeorge
KoukiGeorge's Avatar
KoukiGeorge is an unknown quantity at this point
s14
Originally Posted by Bushido View Post
hydro drift championship
^^^^^ LMAO!!!!!!!
KoukiGeorge is offline
Old 09-26-2013, 07:55 PM   #176
hellion240sx
Thanks obeewon! Might sig that lol.
Old 09-26-2013, 07:59 PM   #177
chriskilla2
chriskilla2 is an unknown quantity at this point
Sigh.........
chriskilla2 is offline
Old 09-26-2013, 08:24 PM   #178
S14DB
AFC #1
S14DB's Avatar
and that is after he launched it off a dirt jump...
S14DB is offline
Old 09-26-2013, 08:58 PM   #179
xoxide
xoxide's Avatar
Yes. And Had a bicycle helmet on.... Cant remember the guys user name, but he posted on here awhile back and on my local 240 forums.
xoxide is offline
Old 09-26-2013, 10:21 PM   #180
ghoti
ghoti's Avatar
ghoti is an unknown quantity at this point
...and nobody else caught this...
Yeah. 5 pages and no one caught this
We use a produck called Jabrock, which is plywood impregnated with resin and compressed at high pressure. Yeah, that's not cheap either. Plywood is NOT strong enough, and it does NOT work fine. It is ghetto, cheap-ass, backwoods, redneck bullshit.
Hot Jabroc shots...
I would be REALLY interested in knowing more about that material. I would be willing to bet that it's extremely expensive hardwood and probably specially treated to be more durable, similar to jabroc. That pic was posted in another thread with a similar topic a few years ago though.
Originally Posted by zerodameaon View Post
Bet you it is just jabroc
EDIT:
A reverse image search reveals it is rosewood(supposedly) and no doubt just turned into jabroc from veneers.
Key is hardwood(Jabroc) not soft wood like pine.
Jabroc would be ideal, but that shit's expensive.
I LOVE Jabroc.
as for jabroc etc, they say it has weight to strength ratio better than steel, but you gotta use like a 1 inch thick plate, while if you made it from steel you would use 2mm...
Originally Posted by tiggertsi View Post
jabroc, oh the irony!
Originally Posted by Def View Post
And you people are seriously making me facepalm - jabroc is not used because it has high strength or anything - it's used as the WEAR SURFACE on the bottom/sides of splitters and planks because it's tough, wear resistance, and solid.
Originally Posted by SaNTi View Post
^ That shit always scares me... and I clinch my asshole a little bit.
ghoti is offline
