Old 04-27-2009, 06:53 PM   #24
GSXRJJordan
GSXRJJordan's Avatar
Originally Posted by Deftec View Post
Do you really think that would cause the relays to burn up though(car not cooling, fans running too long?) The car ran fine for about 2 weeks with this setup since I changed it to 2 relays, and it just stopped the other day when I posted this.
Nope, if the relays are truly bad (you test them by putting 12V current on one side of the coil and ground on the other - coil is 85 and 86 pins - and seeing if it 'clicks'), it's because you're passing too much current though them, or you've got it wired up wrong (fan power through the coil instead of the high-current circuit - 30 and 87 pins). I'd check all your crimps, as well as your ground (ground to the frame rail, or sheet metal welded to the frame rail - most of the car is simply glued together and does not handle high current well.
Update, took the car out, ran fine for a while, got it home and parked it, antifreeze starts blowing everywhere. The relays burned up again. I made 100% sure all air/etc was out of it. So the only option I can really do now is to take the thermostat out and see what it'll do.
If the thermostat wasn't opening, the radiator (and the water inside of it) wouldn't get hot, your engine would just melt itself to hell. You need to re-bleed the system, with the front elevated, heater on, until you get a solid stream of coolant coming out of the bleeder port - then drive the car, observe, and repeat.
