Old 05-23-2009, 08:58 AM   #1
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
driveshaft problem(pics)
I've search but couldn't find my answer, i install my sr20 in my 90 coupe and the shaft has space between it and the tranny. I don't remember it being that much space when i had my sr in my 93 coupe, is this normal? everything is bolted up too.
ecuastyle84 is offline   Reply With Quote
Old 05-23-2009, 09:01 AM   #2
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
I've seen the same thing on multiple cars. it's got enough inside that I wouldnt worry about it
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 05-23-2009, 09:04 AM   #3
Sileighty_85
Sileighty_85's Avatar
its fine
you could have an ABS D/S in a non ABS chassis
other than that you have more than enough of the D/S shaft in the tranny
is the car on the gound in the pics?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-23-2009, 09:29 AM   #4
ecuastyle84
Originally Posted by Sileighty_85 View Post
its fine
When you lower the car on the ground it will push the D/S a little more in to the tranny
i doubt i have a abs d/s cause i bought the car from the original owner which was a old lady, she left the car bone stock when i got it...the car is in the ground in the pics...you think i should put the dust shield on it to protect it from debris? i still have the sr one and i could trim it to size to make it fit.
Old 05-24-2009, 07:30 AM   #5
ecuastyle84
After searching around I found out that I do have a abs driveshaft in my non abs chassis...I heard it will fine but the only thing is that i can't punch it when I'm driving it...is this true? Would I be better off getting a non abs driveshaft to be safe and avoid any damage to the driveshaft or tranny?
Old 05-24-2009, 10:25 AM   #6
I LUV MY S13
I LUV MY S13's Avatar
better to be safe than srry...
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 05-24-2009, 10:31 AM   #7
Sileighty_85
i saw a product a company made to where it was a ABS D/S spacer thatyou sandwitched inbetween the diff and D/S
後輪駆動車1番
1986 SR86 - 200ish
Old 05-24-2009, 10:43 AM   #8
ecuastyle84
do you know what company exactly? Is there a website for it?
Old 05-24-2009, 11:05 AM   #9
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
seriously dude? How is the SUSPENSION of the car going to push the DS into the tranny more? The diff is connected to the FIXED subframe, which is connected to the FIXED tranny mount. If you have that much slop then something is very, very wrong. I wouldn't drive my car like that, but it's totally up to you. I would get the correct driveshaft and DO IT RIGHT the first time.
khilgers is offline   Reply With Quote
Old 05-24-2009, 11:06 AM   #10
Killa_D
Killa_D's Avatar
Trader Rating: (39)
Killa_D can only hope to improve
Feedback Score: 39 reviews
ether get a non abs drive shaft or a abs diff lol. I wouldn't leave it like that.
Killa_D is offline   Reply With Quote
Old 05-24-2009, 11:12 AM   #11
slider2828
slider2828's Avatar
Neither of that... THat is a NORMAL space, because he didn't put the dust ring on, or lost the dust ring, which normaly would cover that space.
Turn and Burn!
Old 05-24-2009, 11:20 AM   #12
khilgers
I don't have the dust ring installed on mine and my DSS driveshaft seats all the way in.
Old 05-24-2009, 11:36 AM   #13
Sileighty_85
HAHA my bad i was thinking about a solid axles lol
Ive been looking at pics of my old Levin so i guess i got stuck on it.
後輪駆動車1番
1986 SR86 - 200ish
Old 05-24-2009, 12:19 PM   #14
Souljahzs13
Trader Rating: (66)
Souljahzs13 is an unknown quantity at this point
Feedback Score: 66 reviews
Yea it seems the dust ring is missing on the tranny, just slap on a later model of the j30 vlsd like a 95-96 so that it has the 6 bolt output for direct bolt on. The abs sensor on the pumpkin will fill in that gap and your driving will be a little more fun.
Souljahzs13 is offline   Reply With Quote
Old 05-24-2009, 01:07 PM   #15
slider2828
slider2828's Avatar
Don't put a non abs drive shaft on a abs diff. On stock the balance of the center carrier is going to be thrown off.
DSS is different, single piece and btw I have a DSS and it doesn't seat all the way in. ABS drive shaft on ABS diff, but is perfectly covered by my dust ring.
Turn and Burn!
Old 05-24-2009, 01:18 PM   #16
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
100% correct. That is normal, what isnt normal is if its flush without the dust collar.
I removed my dust collar, couldnt get the 1pc on with it attached.
OP you have the correct setup, no worries
Bigsyke is offline   Reply With Quote
