Yeah I'm just throwing ideas out and what I find...funny thing is I just have a nearly stock ka. So a lot of this stuff is kinda new, but makes for good reading and maybe learning something new. Just really interested in what the problem is, cause I imagine it being quite frustrating
#5 |
![]() Join Date: Dec 2004
Trader Rating: (58)
The car is reacting like one that would be in limp mode.
I know this sounds funny, but how is the diagnostic screw on the ECU itself? I've seen cars develop oddness like this when screws are half ass broken, or over adjusted etc etc. Part throttle all the way to redline, but unhappy when goosing it (just like your video) Another thing to potentially check is the condition of the MAFS and the CAS itself. They are two other parts of the system that would trigger limp mode or similar symptoms (as will the coolant temp sensor, but that's unlikely in this instance). With so many SR cars, there is no way to swap and test? It's not the BOV (if it wasn't strong enough you won't even make boost, maybe 1 to 2 psi) , I really doubt it's the pipes (plenty of cars with crappy welds run just fine), and I also doubt the O2 sensor difference(as when you go WOT it's ignored on a stock ECU, and just cruising around it's used...yours works fine cruising around). These is the same harness and same components you've always had/used?
#6 | ||||
![]() Join Date: Sep 2004
I do believe this cluster has been tampered with. But again that's not a problem because the temp sensor for the ecu is completely separate. And I've put a new one on the car. Quote:
The cas on the other hand could be the culprit, my hot pipe literally touches it. And may have damaged it, visually it looks fine. But I know electronics normally aren't heated to 200 degree's either. Quote:
One day we did turn the s13 on without a battery in it just to move it. Stuck a battery in, started the car removed battery and moved the car to pull the engine. It ran funny of course but I don't know what caused that. |
#7 | ||||
Trader Rating: (58)
If these jiggles into the slightest bit of diag mode, the car do EXACTLY what you are experiencing...when I first got my SR running ages ago, it did what your car is doing...this is why I always check that little POS screw out as some of the lamest electrical problems can result from that thing not being happy. Again, food for thought. Maybe not your solution, but something to keep in mind. Quote:
I'd start be re-introducing the KS that you removed, and look at whatever was done to convert it to the s14 harness. If it ran before, and the engine was all happy before, then you just gotta look at what was changed. It's an electrical issue for sure, so I'd spend less time looking at hardware (pipes leaks etc etc) at this point, as it's not going to fix the stumble.
#8 |
![]() Join Date: Nov 2005
If you want to pay for sending me that valve cover back and forth, I'll give it a decent polish job for free. It won't be mirror finish, but it will look better than that! hahaaha.
#12 |
Thanks a lot, I appreciate it. I feel the same way about Forrest Wangs S14... looks like a boring black car on vskf's in pictures. then you see it in person and it's even quiet while drifting.
#14 |
I think Flybert had some similar problems with his car, turned out to be a bad maf... that fixed it for a bit. he got a power fc d-jethro and eliminated the maf and car runs great now.
I've pretty much narrowed it down to an engine management system to fine tune everything to the bone and just switch to map. I hate dealing with maf, but the cost of converting doesn't even seem to be worth it. I just want to drive my car... |
#17 | ||
Trader Rating: (58)
Again, it's a crude way to 'fix' an issue. Quote:
If you just want to drive your car, and aren't going for the biggest HP, just throw a rom ecu on the car and enjoy it. I'd hate to spend all that cash on a EMS with a map to fix such an easy issue ya know, as it's still not guaranteed to fix the issue. Super Easy. Just get a plug from any old Nissan and wire it direct. I like keeping the port on the passenger side as well, as it eliminates cables all across the steering wheel and my legs. It's a great tool.
#18 | |
and or just directly wire it to the ecu harness its 5 wires only
built ka-t |
#19 |
I have the plug. I just don't have the wires in place on my f3 plug for the consult. I know which pins it is, I just snipped the wires and tied them to the side. There is a post on here somewhere to show how to wire it back up.
But I eventually plan on getting a twin scroll setup for my engine hence why I would buy a standalone engine management system. I have a few knock sensors but even on my KA both still threw 34. It's normally some gay wiring issue. My maf wiring is fine, because I can put a bad maf on their or keep it unplugged and it runs limp and makes my spark plugs black, backfires and all that madness. this was with a boost leak before I changed the turbo housing, same wiring setup. before I did the knock sensor trick. |
#20 |
So I flipped the ECU today to do the proper code procedure. I believe I left the ecu in the position to read codes, 55 when I flipped it around automatically when I put it on the on position.
So I did the red bulb mode 1 engine off testing, bulb works. pass. I did the mode 1 engine one test, engine warm 2000rpm, no light. pass (if the light comes on it means bad ecu or cam angle sensor error.) I did the mode 2 engine off test after running the engine, engine off key set to on, 5 slow blings, 5 fast blinks. pass I did the mode 2 engine on test, 5 slow blinks at running temp solid 2000rpm rev. pass (this is to make sure the 02 sensor is working.) So I'll let you know if it runs any different now that it's back to it's proper position all the way counter clockwise. |
#21 |
My car officially hates me...
drove to LA today went to girlfriends moms, around the corner from the police academy... some cops roll by my car, check it out then do burn outs onto the on ramp lol. I'm driving home in bumper to bumper traffic after stopping in old town pasadena to pick up new years tickets to menage. I hear a pop and my battery and brake light come on, I immediately pull off of the freeway in front of someones house, pop my hood and somehow the alternator belt came off, and in the process grabbed my TPS sensor and snapped it off of the throttle body. Wires are a little fucked, but both studs that hold it in place are now broken inside of the throttle body. I am sitting here trying to figure out how in the fuck i'm going to get this belt back on the alternator, turns out the nut that holds the pulley in place came loose. So it's been vibrating back and forth and gave the belt enough slack to come loose. So I took the nut off and the pully, wrapped the belt around it and pulled it back over it's stud, screwed on the nut and secured it temporarily with the gum I was chewing. The throttle position sensor I grabbed two zip ties and tied it down in place for the time being. It got me home, no problems. FML. |
#22 | |
![]() Join Date: Feb 2006
For real. The car is just working its problems out. Dont be too discouraged. You'll get everything worked out I'm sure. Wish I could give you the answer but looks like you've been over everything I can think of or someone has mentioned it. But the fact that the ECU is giving you 55 makes me suspect a MAF. ECU won't see a bad MAF, and the idle test/limp mode test is not 100% fool proof. OR there is a leak that opens up at boost. Can you drive smoothly past 4 grand without boosting or does it break up either way? A) If it's under boost I had an issue with my spark blowing out due to gap (I was at 22 psi). B) Or it could be a bad coil pack, they break up intermittently when going bad especially higher rpm under boost. Check them for cracks. C) Also check your timing. Restab the CAS per FSM, even go as far as checking the dimples on the chain. Last edited by OBEEWON; 12-30-2009 at 12:25 PM.. |
#24 | |
Trader Rating: (58)
If you did the wiring, I'd just recheck what I've done at that point and go from there. I (myself) dont' trust myself with the wiring stuff...to me it's cheaper to just pay 100 bucks to get it done...man oh man I'd be wanting to shoot people over wire issues. As I tell my buddies...I'll stick with engine building
![]() Quote:
However the stumper, is that hte car will rev and pull to redline, so long as he doesn't go WOT immediatly...but can at redline...it's very odd. Did you watch the video? It's not a hardware issue if you ask me...electronical for sure (including maf/sensors). I'm just confused as to why it's depending on part throttle...maybe it's reverting to some sort of wacky pull timing map, but it shouldn't restrict the RPM's from revving...which is why I initially thought it was failsafe mode of some sort, or the stupid ecu holding out...it's just odd odd odd.
#25 | |
I had a hairline crack on my hotpipe that opened up to about 1/8 inch under pressure. Couplers and aluminum charge pipes especially like to open up when boost is climbing. Usually found on the higher pressure side of the intercooler before the pressure drop. |
#26 |
Trader Rating: (58)
Ah man that's a killer! Of all things to bust off too, the freakin TPS
![]() Did the car run any better? Who did the harness for you, yourself?
#27 |
I did the harness myself...
car didn't really run any differently under load. I think what pisses me off the most is after I had to zip tie the tps back onto the throttle body for the time being low end response is like twice as good as it was before, but still breaks up past 4000 rpms lol. |
#29 |
the belt didn't snap or get damaged, the alternator just let it come loose. Luisgonz said that it felt loose and it has been squealing as of a few weeks ago. I should've tightened it.
