Old 09-25-2006, 06:40 PM   #1
TurK
TurK is making his/her stupidity well-knownTurK is making his/her stupidity well-knownTurK is making his/her stupidity well-knownTurK is making his/her stupidity well-knownTurK is making his/her stupidity well-known
Send a message via AIM to TurK
SR s14 SR problem...bah
Alright i have this problem every since i took the s14 sr from my 96 and put it on my current 98.....the problem i have with it is that....if i let the car idle for a good 4-5 minutes it wont let me rev past 2000RPM for some reason..? Its the same motor/tranny/harness that was in my 96...all i did was just take the whole thing and put it in my 98......and now the nissan comp wont read it...having the idling problem......i was wondering if anybody can help me out on this?
TurK is offline   Reply With Quote
Old 09-26-2006, 05:32 PM   #2
TurK
again looking for any kind of help.... thanks
Old 09-27-2006, 12:34 AM   #3
street_white180sx
street_white180sx's Avatar
street_white180sx is an unknown quantity at this point
SR
check your maf cicuitry might have a bad ground. something is causing your car to go into safe mode. most cases with the car not goin past 2000 rpm is usually maf related. so start off by checking that out and also check the ecu for any codes this might help you pinpoint your problem.
1993 S14 Silvia Slant Top, Blitz Bov, Fmic, Catback exhaust, HKS evc 3
street_white180sx is offline   Reply With Quote
Old 09-27-2006, 10:59 AM   #4
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
yup sounds like your maf is putting you in limp mode. unplug your maf and see if it runs better or the same.
@woooster on instagram
kuruptR is offline   Reply With Quote
Old 09-28-2006, 07:21 PM   #5
TurK
yes my maf is kind of cracked as you guys can see in this picture towards the bottom corner....would this cause it? Never tried to see if i can run with the maf unpluged.
Old 09-28-2006, 08:02 PM   #6
IDriveFords
IDriveFords is a well-known jackass
A crack in the MAFs plastic shouldn't hurt it unless something conductive got under it and messed up the circuitry in there. This is quite possible since your cars probably exposed to all the elements. Usually if you unplug the MAF the car won't start (not sure with SR). Check your ECU for codes.
IDriveFords is offline   Reply With Quote
Old 09-28-2006, 09:28 PM   #7
TurK
ive never haven taken out the sensor so nothing could of gotten under it. I ran the car with the maf unpluged.....that didnt go to welll..
Old 09-29-2006, 01:50 PM   #8
Slidin240Wayz
Slidin240Wayz's Avatar
I hope you didn't drive with it?!?!?
Air escapes from infinitismal spaces in the piping= boost leak
Dirt can get in the cracked maf. I would try another MAF.
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 09-30-2006, 09:36 AM   #9
TurK
naw i didnt drive with it off....just tried giving some gas a little bit. Yeah i need a s14sr maf sensor....
anybody have for sale?
Old 09-30-2006, 02:15 PM   #10
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
you can use one from a KA
RedtopTech is offline   Reply With Quote
Old 09-30-2006, 02:23 PM   #11
Slidin240Wayz
I highly doubt it the car will run as it should.
Carlos
Old 09-30-2006, 02:24 PM   #12
SRd240sx
SRd240sx's Avatar
SRd240sx will become famous soon enoughSRd240sx will become famous soon enoughSRd240sx will become famous soon enoughSRd240sx will become famous soon enough
Send a message via AIM to SRd240sx
I have an S14 SR MAF sensor. Was from my Kouki S14 SR. I swapped in a z32 MAF. It's in great working condition. Let me know if you're interested. PM me or something
SRd240sx is offline   Reply With Quote
Old 10-07-2006, 05:57 PM   #13
TurK
do you still have it?
