Old 11-08-2006, 09:50 AM   #1
leosr20
leosr20 is an unknown quantity at this point
fuel gauge
hi all
can anyone help please!! have a small problem with my fuel gauge!! when the car is running the fuel gauge goes empty!! but if you put the ignition on the the gauge will work fine but as soon as you start the car or even crank the engine over the gauge goes empty!!
i have put a big bosch pump and thats it
leo
leosr20 is offline   Reply With Quote
Old 11-08-2006, 10:54 AM   #2
Slidin240Wayz
Slidin240Wayz's Avatar
I suggest going over your connections.
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 11-11-2006, 04:59 PM   #3
leosr20
been in the garage for about an hour now.i think i need the sender unit on the fuel pump holder!!
i removed the fuel pump with the holder and moved the float up and down,it didnt work very well!! the only time it worked 100% is when i pushed the float close to the contacts.
i found one black wire broken on top of the sender unit,re-connected but still the same.
am i right anyone?
