Old 12-15-2006, 02:37 PM   #1
arian23
arian23 is an unknown quantity at this point
s14 Is it ok to use the spacer w/ Tein tie rods for everday driving
I have the tein tie rod and ends for my S14 and I was wondering if I should put the spacer. I want that extra steering angle but I was wondering if it is ok for everyday street use. I checked the write up on the Tein tie rods but it didnt talk about the spacer being good or bad.
arian23 is offline   Reply With Quote
Old 12-15-2006, 03:34 PM   #2
Slidin240Wayz
Slidin240Wayz's Avatar
Yes, you can use them for daily driving. Make sure apply thread-lock before tightening them down.
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 12-15-2006, 04:04 PM   #3
S13 Charlie
S13 Charlie's Avatar
S13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura about
Send a message via AIM to S13 Charlie
Hell yeah! It makes parking in tight spaces so much easier! I've had mine on my car for the last two years with no issues at all. But, just as the above Slidin240wayz mentioned get some loctite threadlocker, it's pretty cheap and good to have around anyway.
S13 Charlie is offline   Reply With Quote
Old 12-15-2006, 04:56 PM   #4
HyperTek
3 years on mine. i didnt put threadlock, doesnt hurt not to, but it adds a lil security to your mind.
Keep it Classy
Old 12-15-2006, 08:45 PM   #5
Slidin240Wayz
I did not put threadlock on mine and I have been riding on them for about 2+ years without any issues.
Carlos
Old 12-15-2006, 08:55 PM   #6
!Zar!
!Zar!'s Avatar
Go ahead and toss them on.
I'd also recommend tossing thread lock on there for added safety.
Only adverse affect from it is increase in bump steer.
Old 12-16-2006, 06:07 PM   #7
arian23
Increase in bump steer??? I thought when I get the beefier rod its going to reduce bumpsteer a little bit.
Old 12-16-2006, 07:54 PM   #8
smelly240
smelly240's Avatar
u might be confused what bump steer is -
longacre racing
http://www.racerpartswholesale.com/longtech3.htm
AutoRepair
http://autorepair.about.com/library/...bldef-043a.htm
pretty much - it moves the joint on the inner rod outward increasing the angularity of the rod... the more of an angle the rod is on - the more affect the car compressing down has on the steering alignment (toe and such)
so its like when u hit a weird dip in the road or turn hard - the car will squat or roll and turn the wheel some...
its worse if ur rods run uphill bc ur slammed without spacers on the outer ends (i was like that a while and it SUCKED hitting dips on the highway.)
smelly240 is offline   Reply With Quote
Old 12-17-2006, 02:53 AM   #9
serdaman
serdaman can only hope to improve
tie rods
my steering rack is leaking from the tie rod area,if i get new(tein)rods will this stop the leak or do i need to have my rack rebuilt b4 i get the tie rods>
thx
serdaman is offline   Reply With Quote
Old 12-17-2006, 08:36 AM   #10
smelly240
smelly240's Avatar
get a new/rebuilt rack... tie rods dont seal anything. Also - replace the boots, and steering rack bushings while u have it apart.
Old 12-17-2006, 08:47 AM   #11
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
use the spacers
daily driving- makes u-turns easier
lilredstiffy is offline   Reply With Quote
