Old 07-16-2007, 05:30 PM   #1
legacy927
legacy927's Avatar
legacy927 will become famous soon enoughlegacy927 will become famous soon enoughlegacy927 will become famous soon enoughlegacy927 will become famous soon enough
help with stalling problems on s14
Hi guys,
I need some help with the problem i've been having lately. I have a 95 240 (KA), i recently replaced new spark plugs, fuel filter, battery, o2 sensor and starter. The car is auto, and sometimes it would stall out of no where..especially when i come across a full stop or slowing down...it struggles to stay on...sometimes i have to put it on neutral & gas it inorder to stay alive...otherwise it would just die on me..remember this car is auto...
i have checked the battery terminals make sure its tight. I played around with the MAF sensor..its fine...i even changed the air filter...i had the ecu read..nothings wrong...everything in the car is stock...so i really dont know whats wrong with it...
could it be bad grounds?? can someone give me some suggestions where to look at...
thanks guys...
legacy927 is offline   Reply With Quote
Old 07-16-2007, 05:39 PM   #2
BoNyG515
BoNyG515's Avatar
BoNyG515 is an unknown quantity at this point
Send a message via AIM to BoNyG515
it sounds like you may have a bad or clogged idle air control valve. the iac allows air into the engine especially under decelleration or at closed throttle. try cleaning it and let us know wassup
"Sugar we're going down swinging..."
BoNyG515 is offline   Reply With Quote
Old 07-16-2007, 05:42 PM   #3
na3j nitsuj
na3j nitsuj's Avatar
na3j nitsuj is an unknown quantity at this point
i dont think it would be bad grounds...
more likely mafs connection or vaccum leak.
sometimes the pins on the mafs connector does not touch the terminals cause the can be bent easily.
check your spark plug gaps again and clean you IACV.
na3j nitsuj is offline   Reply With Quote
Old 07-16-2007, 07:57 PM   #4
Max_PSi
Max_PSi's Avatar
Max_PSi will become famous soon enoughMax_PSi will become famous soon enoughMax_PSi will become famous soon enough
Take your intake off and check your throttle body. If its all black I would get some throttle body cleaner and clean it up as well.
Get a squeeze bottle and use soapy water to spray down your vacuum hoses, if something starts to bubble up you may have a leak.
Max_PSi is offline   Reply With Quote
Old 07-16-2007, 11:11 PM   #5
240tek
240tek is an unknown quantity at this point
what's your idle set to? I agree with Bony, check wiring to IACV.
240tek is offline   Reply With Quote
Old 07-17-2007, 01:38 AM   #6
Vision Garage
Vision Garage's Avatar
Vision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfection
Send a message via AIM to Vision Garage
fuel pump going out?
Vision Garage is offline   Reply With Quote
Old 07-17-2007, 08:15 AM   #7
Slidin240Wayz
Slidin240Wayz's Avatar
Check your vaccuum lines...
Slidin240Wayz is offline   Reply With Quote
Old 07-17-2007, 09:11 AM   #8
legacy927
legacy927's Avatar
thanks guys for the tips..im gona look into it this wkend since i couldnt take the day off...
my car have its days..somedays it works great..somedays it just dies on me...this happened before like few months back..but later on..it just works fine again...so i didnt really bother..cuz i was planning on swapping a SR..but for the meantime..i need to fix it cuz its basically a daily driven car...
thanks again guys...ill keep u guys updated..
any other suggestions..please let me know...thanks
Old 07-18-2007, 12:53 AM   #9
240tek
Now I think of it, you'd probably get a code if IACV was clogged or wiring messed. Something sounds goofy with your Air/Fuel and you mentioned you changed your Upper O2 sensor (or lower???) I wonder if you might have that mysterious Coolant Temp Sensor problem tho.
Old 07-18-2007, 12:58 AM   #10
240tek
Drain your coolant, remove the sensor, test for specs, if it's bad (the 2 wire one with red plug) then replace it, this is your most likely cause of this issue.
Old 07-20-2007, 03:16 PM   #11
legacy927
legacy927's Avatar
hey guys...
i've cleaned the IACV...it was dirt black...so as of now..it runs fine...but im gona wait n see if thats was the problem.
i hope dis is it...
THANKS GUYS!!!
Old 07-20-2007, 08:21 PM   #12
240tek
Good to hear, I was waiting to see what the deal was. It's hard to get to, eh? The other possibility would have been the CTS, best of luck!
Old 11-08-2007, 06:02 PM   #13
Torrid
Torrid is on the path to ruinTorrid is on the path to ruin
Sorry, wrong thread
Torrid is offline   Reply With Quote
Old 11-09-2007, 01:41 AM   #14
S14Laco
S14Laco's Avatar
S14Laco is an unknown quantity at this point
check condition of your belts too, could be slipping badly enough to cause this?
S14Laco is offline   Reply With Quote
Old 11-09-2007, 07:20 AM   #15
legacy927
legacy927's Avatar
thanks...i totally forgot about this post...
im running a sr20 now...
